Connect up to 8 different GbE (4 PoE+) devices, using this IP30 industrial Ethernet switch with intelligent Layer 2 management. Easily deploy or scale your network with this Gigabit Ethernet switch, by adding eight copper Gigabit Ethernet connections, including four PoE+ ports. This IP30 industrial network switch provides intelligent Layer 2 management. Its rugged, compact design and wall-mount option with front access make it ideal for demanding applications, even where space is limited.
This Gigabit Ethernet switch lets you expand your network by connecting up to eight RJ45 devices (four PoE+). The 8-Port switch enables up to eight users to share files and devices, such as printers and scanners, over a LAN connection, by enhancing your existing network capacity with additional ports.
The switch gives you the freedom to place your equipment in locations where power outlets are not available, with support for Power over Ethernet Plus. The network switch provides abundant PoE power, with up to 30 watts for each PoE port (120W budget).
With its compact design, you can wall-mount the Gigabit switch to provide convenient front access to ports and indicators. It's ideal for a wide range of applications, including tight installation areas with significant electromagnetic interference, such as control cabinets and panels. The network switch is also DIN-rail mountable.
The switch delivers efficient and stable performance, with Layer 2 management capabilities. This lets you control packet traffic on a busy network, and customize your settings to achieve optimal network performance, offering improved efficiency and reliability.
This rugged network switch features an IP30-rated metal housing and extended temperature range of -40°C to 75°C, which makes it ideal for a wide range of operating conditions. The sturdy metal enclosure offers durability, even in harsh industrial environments.
With support for 10/100/1000Mbps transfer speeds, this managed switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation. This lets you connect your network devices quickly and easily, with little to no configuration required.
To help prevent any unnecessary downtime, the switch features redundant 12-58V DC terminal block power inputs, which ensures seamless operation in the event of power dips or failures.
- StarTech.com Industrial 8 Port Gigabit PoE Switch - 4 x PoE+ 30W - Power Over Ethernet GbE Layer/L2 Managed Network Switch -40C to +75C (IES81GPOEW) - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 + 4 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 120 W
- Performance
- Data transfer rate: 2 Gbps
- Capacity
- Buffer capacity (MB): 0.512
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMP, MLD
- Remote Management Protocol
- HTTP
- Layer 2 switching, IPv6 support, full duplex mode, wall mountable, Trivial File Transfer Protocol (TFTP) support, tagged VLAN, 6KV ESD Protector, 802.1x authentication, Internet Control Message Protocol (ICMP), 6KV EFT protector
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- DC 12 - 48 V
- 14.8 cm x 13.4 cm x 2.5 cm
- 625 g
- Black
- 2-year warranty
- Enclosure Type
- Wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 120 W
- Performance
- Capacity
- 9KB
- Routing Protocol
- IGMP, MLD
- HTTP
- Status Indicators
- Power, PoE
- 4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x terminal block
- Voltage Required
- DC 12 - 48 V
- Black
- Included Accessories
- 4 magnets, DIN-rail mounting kit, 4 x screws, attaching pins, locking pins, 4 washers, 8 RJ45 dust caps
- MTBF
- >100,000 hours
- FCC, RoHS, WEEE, IP30, RCM
- 14.8 cm
- 13.4 cm
- 2.5 cm
- 625 g
- Limited warranty - 2 years
- -40 °C
- 75 °C
- 5 - 95% (non-condensing)
StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch | In Stock | £187.91 |
StarTech.com 8-Port (4 PoE+) GbE Switch | In Stock | £197.04 |
StarTech.com 8-Port GbE Switch - Managed | In Stock | £140.93 |
StarTech.com GbE Switch, 8x RJ45 + 2x SFP Ports | In Stock | £187.91 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £299.31 |
