StarTech.com 7m 40G QSFP+ Active DAC Cable
Quicklinx: D9V5WS00 Mfr#: QSFPH40GACU7
Length: 7m
Colour: Black
Select:
  • 7m
£255.82 ex VAT
£306.98 inc VAT
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium distance applications such as across-rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-ACU7M Compatible 7m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Active Transceiver Module DAC, 40GE QSFP+ Cable Firepower ASR1000 - Lifetime Warranty (QSFPH40GACU7) - 40GBase direct attach cable - 7 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
7 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
7 m
450 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 7m
Colour: Black
