Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
 - StarTech.com MSA Uncoded Compatible 7m 10G SFP+ to SFP+ Direct Attach Breakout Cable Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Active Transceiver Module DAC, 10GE Breakout Cable - Lifetime Warranty (SFP10GAC7M) - 10GBase direct attach cable - 7 m - black
 - 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
 - Twinaxial
 - Active cable
- Length
 - 7 m
- Connector
 - SFP+ - latched
- Connector (Second End)
 - SFP+ - latched
 - Black
 - Limited lifetime warranty
- Designed For
 - P/N: PEX10GSFP
- Network Cable Type
- Technology
 - Twinaxial
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Impedance
 - 100 Ohm
 - Active cable
- Length
 - 7 m
 - 450 g
 - Black
- Connector
 - SFP+ - latched
 - SFP+ - latched
 - FCC, RoHS, MSA
 - 0 °C
 - 70 °C
- Designed For
 - P/N: PEX10GSFP
                        StarTech.com 10m 10G SFP+ Active DAC Cable | In Stock | £40.94 |
