Connect your Cisco 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
- StarTech.com Cisco SFP-H10GB-ACU7M Compatible 7m 10G SFP+ to SFP+ DAC Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Active SFP+ Transceiver Module DAC Cable, Cisco Firepower ASR9000 - Lifetime Warranty (SFPH10GBACU7) - 10GBase direct attach cable - 7 m - black
- 10GBase direct attach cable - SFF-8431/SFF-8432
- Technology
- Twinaxial
- Active cable
- Length
- 7 m
- Connector
- SFP+ - latched
- Connector (Second End)
- SFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-H10GB-ACU7M
- Limited lifetime warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Impedance
- 100 Ohm
- Active cable
- Length
- 7 m
- 450 g
- Black
- Connector
- SFP+ - latched
- SFP+ - latched
- FCC, RoHS, MSA
- 0 °C
- 70 °C
StarTech.com 10m 10G SFP+ Active DAC Cable | In Stock | £110.11 |
StarTech.com 7m 10G SFP+ Active DAC Cable | In Stock | £76.75 |
