Brand
StarTech.com 7 Port USB-C Hub - C to C & A
Quicklinx: DL00WS00 Mfr#: HB30C5A2CSC
Type: USB Hub
Interface: USB
Ports: 7
Form Factor: External
23 in stock
£75.01 ex VAT
£90.01 inc VAT
Turn a USB Type-C port on your laptop into five USB Type-A ports (5Gbps) and two USB Type-C ports. This USB-C hub turns your laptop or desktop USB Type-C or Thunderbolt 3 port into four standard USB-A ports, one USB-A fast-charge port, and two USB-C ports. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 7-port USB hub provides convenient port access. The extended length of the supplied cable offers the flexibility to position your hub and USB devices as needed, in order to create a comfortable, space-efficient work area. The ports are sufficiently spaced to plug or unplug your USB devices without needing to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or avoid the hassle of swapping connected devices on your port-limited laptop.
The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2.
StarTech.com 7 Port USB C Hub with Fast Charge Port, USB-C to 5x USB-A 2x USB-C USB 3.0 (USB 3.1/3.2 Gen 1 SuperSpeed 5Gbps), Self Powered Type-C Hub w/ Power Adapter, Desktop/Laptop Hub - Windows/macOS/Linux (HB30C5A2CSC) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
5 x SuperSpeed USB 3.0 + 2 x USB-C
Plastic housing, Fast Charging Port
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V 1 A
14.9 cm x 6.5 cm x 2.4 cm
250 g
Black, silver
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X VIA VL813
Status Indicators
Active
4 x USB 3.0 Type A , 1 x USB 3.0 Type A Fast-Charge , 2 x USB-C
External power adapter
Power Provided
DC 12 V - 4 A
AC 120/230 V
Electric Current Required
1 A
48 Watt
Black, silver
1 x USB cable - 1 m
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
14.9 cm
6.5 cm
2.4 cm
250 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
DL00 StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £18.82
DL00 StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £21.36
DL00 StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.99
DL00 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £52.51
DL00 StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £30.25
DL00 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £19.16
DL00 StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £13.94
DL00 StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
DL00 StarTech.com 1m USB A to C Cable - USB 3.0 In Stock £9.91
Type: USB Hub
Interface: USB
Ports: 7
Stock Status: In stock
