StarTech.com 7 Port USB 3.0 Hub Desktop
Quicklinx: B2WLWS00 Mfr#: ST7300U3M
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 7
Form Factor: External
More than 50 In Stock
£62.29 ex VAT
£74.74 inc VAT
Connect 7 high-performance devices to your computer or Mac with this compact and rugged hub. The StarTech.com 7-port USB 3.0 hub is your answer for a durable and compact hub that's ideal for desktop or travel usage.
This hub is perfect for a permanent setup with a desktop computer, with a rugged metal housing that can withstand the wear and tear of daily use. Plus, you can attach it to a surface such as a desktop or wall using the included wall-mount bracket.
The compact size and durability of the hub also make it perfectly portable. When you're on the go, its robust design resists damage that can occur when traveling or from back-and-forth trips from home to office.
The ports on this hub are upright, which makes it perfect for IT professionals or anyone who needs to plug and unplug their USB devices regularly. You have lots of room to grip the connectors, without the worry of oversized plugs taking up too much space and reducing the number of available ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub makes your USB ports more accessible and can easily extend the range of your devices by acting as a mid-point repeater.
The ST7300U3M supports the latest USB 3.0 products including UASP-enabled; storage devices. With data transfer speeds of up to 5 Gb per second using SuperSpeed USB 3.0 technology, this high-performance hub is the perfect accessory for your desktop, laptop, MacBook, or UltraBook.
You can also use the hub with older peripherals and computers, with support for USB 2.0 and 1.x devices and no additional drivers or software required for installation.
  • Enjoy desktop convenience or painless portability
    This hub is perfect for a permanent setup with a desktop computer, with a rugged metal housing that can withstand the wear and tear of daily use. Plus, you can attach it to a surface such as a desktop or wall using the included wall-mount bracket. The compact size and durability of the hub also make it perfectly portable. When you're on the go, its robust design resists damage that can occur when traveling or from back-and-forth trips from home to office.
  • Connect devices quickly and easily
    The ports on this hub are upright, which makes it perfect for IT professionals or anyone who needs to plug and unplug their USB devices regularly. You have lots of room to grip the connectors, without the worry of oversized plugs taking up too much space and reducing the number of available ports. With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub makes your USB ports more accessible and can easily extend the range of your devices by acting as a mid-point repeater.
  • Use with high-performance and older devices
    The ST7300U3M supports the latest USB 3.0 products including UASP-enabled; storage devices. With data transfer speeds of up to 5 Gb per second using SuperSpeed USB 3.0 technology, this high-performance hub is the perfect accessory for your desktop, laptop, MacBook, or UltraBook. You can also use the hub with older peripherals and computers, with support for USB 2.0 and 1.x devices and no additional drivers or software required for installation.
StarTech.com 7 Port USB 3.0 Hub (5 Gbps) - Metal Enclosure - Desktop or Wall Mountable - Rugged & industrial Powered USB Expander and Splitter Hub (ST7300U3M) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Metal housing
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V
4.4 cm x 11 cm x 2.4 cm
134 g
P/N: BNDTBUSB3142, MST30C2DPPD, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB3LA
Hub - 7 ports
Enclosure Type
Desktop, wall-mountable
Subtype
USB
Ports
Metal housing
1 x ASMedia ASM1074
7 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
36 Watt
Rubber feet, mounting brackets
1 x SuperSpeed USB cable
FCC, RoHS
4.4 cm
11 cm
2.4 cm
134 g
5 °C
35 °C
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
P/N: BNDTBUSB3142, MST30C2DPPD, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
B2WL StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
B2WL StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £83.04
B2WL StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.59
B2WL StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable In Stock £20.30
B2WL StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.56
B2WL StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £79.99
B2WL StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £24.95
B2WL StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £19.39
B2WL StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £47.38
B2WL StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
B2WL StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £125.88
B2WL StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £127.40
B2WL StarTech.com 7 Port Compact USB 3.0 Hub In Stock £44.74
B2WL StarTech.com 4 Port Portable USB 3.0 Hub In Stock £23.86
B2WL StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
B2WL StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £30.36
B2WL StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £157.01
B2WL StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £178.43
Type: USB Hub
Speed: 5Gbps
Ports: 7
