This TAA compliant 4-port industrial USB hub provides four USB 2.0 ports to connect your devices. The USB 2.0 hub can be surface or DIN rail mounted, providing convenient USB connectivity in a work area, server room, or industrial environment.
The USB hub, with its rugged metal housing and IP30 protection rating, is built to meet the harsh demands of industrial environments. The 15kV ESD Protection (Level 4) reduces the risk of disruption caused by high static industrial environments, which can lead to costly service calls and downtime. To ensure maximum performance, the industrial USB hub provides an extended operating temperature range (-40°C - 85°C).
The hub's wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. For low-power applications, the hub can be operated through the host USB bus power.
For easy port access, the 4-port industrial USB hub can be surface or wall-mounted, and includes an optional DIN rail mount kit. The plug-and-play ports connect easily to printers, cameras, sensors and other devices. Each port also features its own Transaction Translator (TT), to assist with load balancing and ensure each port can operate at peak performance.
- StarTech.com 4 Port USB 2.0 Hub, Metal Industrial USB-A Hub (4x USB-A) with ESD & Surge Protection, Extended Operating Temp -40 to 185°F, Din Rail/Wall/Desk Mountable, USB Expander Hub - Windows/macOS/Linux (HB20A4AME) - hub - 4 ports - TAA Compliant
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 2.0
- Surge protection, 15KV ESD Protector
- USB 2.0
- Power
- DC 7 - 24 V
- 9.5 cm x 5.5 cm x 3.2 cm
- 350 g
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: ITB20D3250
- Hub - 4 ports
- Enclosure Type
- DIN rail mountable
- Subtype
- USB
- Ports
- 4 x USB 2.0
- USB 2.0
- Processor
- X Genesys Logic GL852GT
- Status Indicators
- Power
- 4 x USB 2.0 Type A , 1 x USB 2.0 Type B
- Power Device
- External power adapter
- Voltage Required
- DC 7 - 24 V
- Included Accessories
- DIN-rail mounting kit
- Cables Included
- 1 x USB-A to USB-B cable - 1.8 m
- Plug and Play, FCC, RoHS, WEEE
- TAA Compliant
- 9.5 cm
- 5.5 cm
- 3.2 cm
- 350 g
- Limited warranty - 2 years
- -40 °C
- 85 °C
- 5 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Designed For
- P/N: ITB20D3250
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £62.14 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £82.96 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.32 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £111.14 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £133.39 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
StarTech.com Industrial USB 3.0 Hub | In Stock | £306.30 |
StarTech.com Industrial USB 5Gbps Hub | In Stock | £314.99 |
