StarTech.com 7-Port Industrial USB 2.0 Hub
Quicklinx: DXDYWS00 Mfr#: HB20A7AME
Type: USB Hub
Interface: USB 2.0
Ports: 7
Form Factor: DIN rail mountable
£182.49 ex VAT
£218.98 inc VAT
Add seven USB 2.0 ports to a computer system located in a harsh operating environment, with this DIN rail or surface-mountable metal hub. This TAA compliant 7-port industrial USB hub provides seven USB 2.0 ports to connect your devices. The USB 2.0 hub can be surface or DIN rail mounted, providing convenient USB connectivity in a work area, server room, or industrial environment.
The USB hub, with its rugged metal housing and IP30 protection rating, is built to meet the harsh demands of industrial environments. To keep connections secure and protect against accidental disconnections, the hub supports screw-locking cables. The 15kV ESD Protection (Level 4) reduces the risk of disruption caused by high static industrial environments, which can lead to costly service calls and downtime. To ensure maximum performance in areas with extreme temperature variances, the industrial USB hub provides an extended temperature range (-40°C - 85°C).
The hub's wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities.
For easy port access, the 7-port industrial USB hub can be surface or wall-mounted, and includes an optional DIN rail mount kit. The ports are plug-and-play making it easy to connect printers, cameras, sensors and other devices. Each port in the USB hub also features its own Transaction Translator (TT), to assist with load balancing and ensure each port can operate at peak performance.
StarTech.com 7 Port USB 2.0 Hub, Metal Industrial USB-A Hub (7x USB-A) with ESD & Surge Protection, Extended Operating Temp -40 to 185°F, Din Rail/Wall/Desk Mountable, USB Expander, Rugged - Windows/macOS/Linux (HB20A7AME) - hub - 7 ports - TAA Compliant
Hub - 7 ports
Subtype
USB
Ports
7 x USB 2.0
Surge protection, 15KV ESD Protector
USB 2.0
DC 7 - 24 V
11.2 cm x 6.3 cm x 4.3 cm
500 g
TAA Compliant
P/N: ITB20D3250
Hub - 7 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
7 x USB 2.0
USB 2.0
X Genesys Logic GL852GT
Status Indicators
7 x USB 2.0 Type A , 1 x USB 2.0 Type B
External power adapter
DC 7 - 24 V
DIN-rail mounting kit
1 x USB-A to USB-B cable - 1.8 m
Plug and Play, FCC, RoHS, WEEE
TAA Compliant
11.2 cm
6.3 cm
4.3 cm
500 g
Shipping Weight
700 g
-40 °C
85 °C
5 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
P/N: ITB20D3250
DXDY StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
DXDY StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £85.03
DXDY StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
DXDY StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £108.59
DXDY StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £130.30
DXDY StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £145.20
DXDY StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £182.49
DXDY StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
DXDY StarTech.com Industrial USB 3.0 Hub In Stock £297.86
DXDY StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
DXDY StarTech.com Industrial USB 10Gbps Hub In Stock £175.68
Type: USB Hub
Interface: USB 2.0
Ports: 7
