StarTech.com 10 Port Industrial USB 3.0 Hub
Quicklinx: BST7WS00 Mfr#: ST1030USBM
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 10
Form Factor: External
More than 50 In Stock
£128.27 ex VAT
£153.92 inc VAT
Add ten USB 3.0 (5Gbps) ports with this DIN rail or surface-mountable metal hub. This 10-port USB 3.0 hub gives you the scalability you need in harsh industrial environments. It's designed to meet the advanced requirements of connecting a high number of devices in factory and industrial settings.
With a metal housing, you can depend on this industrial hub even in tough operating conditions. And because it offers more ports than most USB 3.0 hubs, you can access more devices at once, so you can work more efficiently and save time.
Designed for a high volume of connections in industrial environments, this robust USB 3.0 hub offers ten connection ports, unlike most four or seven-port USB 3.0 (also known as USB 3.1 Gen 1) hubs.
With more ports you can connect more devices, such as USB-based control equipment, external storage, and more. Plus, you can avoid the aggravation of connecting and disconnecting devices when all ports are occupied.
The hub also supports USB Battery Charging Specification 1.2, delivering up to 1.5 amps power to each USB port, so you can charge your mobile devices faster than traditional USB ports allow.
This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. And because it supports wide-range 7-24V DC terminal block input, you have the flexibility to power the hub as required, based on your own power input capabilities.
Perfect for factory environments, the rugged hub also supports an extended operating temperature range (0°C to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your connected devices.
With versatile installation options, you can install the hub where it's best suited for your environment. You can securely mount the USB 3.0 hub to a surface, wall, or under a desk, and, it includes optional DIN rail mounts for use with equipment rack installations.
The industrial hub supports the full 5Gbps bandwidth of USB 3.0 and is also backward compatible with previous USB devices. You can connect your legacy USB 2.0 and 1.x peripherals alongside your newer USB 3.0 devices without any disruptions.
  • Perfect for Harsh Environments
    This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. It supports wide-range 7-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities. Perfect for factory environments, the rugged hub also supports a wide operating temperature range (0°C to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your connected devices.
  • Connect & Charge More USB Devices
    Designed for a high volume of connections, this robust USB 3.2 Gen 1 hub offers ten connection ports, for connecting more USB devices and peripherals. The hub also supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a maximum of 50W total, so you can charge your mobile devices faster than traditional USB ports allow.
  • Locate the Hub Where You Need it Most
    With versatile installation options, you can install the hub where it's best suited for your environment. With built-in mounting brackets and included DIN mount rails, you can securely mount the USB 3.2 Gen 1 hub to most surfaces such as a wall, under a desk or rack. StarTech.com offers an external power adapter, ITB20D3250, sold separately. The universal DC power adapter can be used as an alternative, back up or replacement power supply for StarTech.com's line of industrial USB hubs.
  • Works With Your Older USB Devices
    The rugged USB hub supports the full 5Gbps bandwidth of USB 3.2 Gen 1 and is backward compatible with previous USB devices. You can connect your legacy USB 3.2 Gen 1 and 1.x peripherals alongside your newer USB 3.2 Gen 1 devices without any disruptions. The ST1030USBM is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 10-Port USB 3.0 Hub - Metal Industrial USB-A Hub with ESD & Surge Protection - Din Rail, Wall or Desk Mountable - TAA Compliant USB Expander Hub (ST1030USBM) - hub - 10 ports
Hub - 10 ports
Subtype
USB
Ports
10 x SuperSpeed USB 3.0
Surge protection, 15KV ESD Protector
USB 1.1, USB 2.0, USB 3.0
DC 7 - 24 V
19.8 cm x 5.6 cm x 3.1 cm
350 g
P/N: ITB20D3250, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 10 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
Status Indicators
10 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
DC 7 - 24 V
DIN-rail mounting kit, power terminal block
1 x USB power cable
FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2
19.8 cm
5.6 cm
3.1 cm
350 g
70 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
BST7 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £103.00
BST7 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £80.54
BST7 StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.97
BST7 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
BST7 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
BST7 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £110.30
BST7 StarTech.com 7 Port PCIe USB 3.0 Card In Stock £56.73
BST7 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £27.19
BST7 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.79
BST7 StarTech.com 15 ft USB 3.0 A to B Cable M/M In Stock £83.00
BST7 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £128.27
BST7 StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £145.20
BST7 StarTech.com 7-Port Industrial USB 2.0 Hub In Stock £182.49
BST7 StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
BST7 StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £114.51
BST7 StarTech.com 4 Port USB C Hub 10Gbps In Stock £117.38
BST7 StarTech.com Industrial USB 2.0 Hub In Stock £38.22
BST7 StarTech.com Industrial USB 3.0 Hub In Stock £297.86
BST7 StarTech.com Industrial USB 5Gbps Hub In Stock £319.95
BST7 StarTech.com Industrial USB 10Gbps Hub In Stock £175.68
Type: USB Hub
Speed: 5Gbps
Ports: 10
