StarTech.com 7 Port USB 3.0 Hub Desktop
Quicklinx: B2WLWS00 Mfr#: ST7300U3M
More than 50 In Stock
£62.29 ex VAT
£74.74 inc VAT
Connect 7 high-performance devices to your computer or Mac with this compact and rugged hub. The StarTech.com 7-port USB 3.0 hub is your answer for a durable and compact hub that's ideal for desktop or travel usage.
This hub is perfect for a permanent setup with a desktop computer, with a rugged metal housing that can withstand the wear and tear of daily use. Plus, you can attach it to a surface such as a desktop or wall using the included wall-mount bracket.
The compact size and durability of the hub also make it perfectly portable. When you're on the go, its robust design resists damage that can occur when traveling or from back-and-forth trips from home to office.
The ports on this hub are upright, which makes it perfect for IT professionals or anyone who needs to plug and unplug their USB devices regularly. You have lots of room to grip the connectors, without the worry of oversized plugs taking up too much space and reducing the number of available ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub makes your USB ports more accessible and can easily extend the range of your devices by acting as a mid-point repeater.
The ST7300U3M supports the latest USB 3.0 products including UASP-enabled; storage devices. With data transfer speeds of up to 5 Gb per second using SuperSpeed USB 3.0 technology, this high-performance hub is the perfect accessory for your desktop, laptop, MacBook, or UltraBook.
You can also use the hub with older peripherals and computers, with support for USB 2.0 and 1.x devices and no additional drivers or software required for installation.
  • Enjoy desktop convenience or painless portability
    This hub is perfect for a permanent setup with a desktop computer, with a rugged metal housing that can withstand the wear and tear of daily use. Plus, you can attach it to a surface such as a desktop or wall using the included wall-mount bracket. The compact size and durability of the hub also make it perfectly portable. When you're on the go, its robust design resists damage that can occur when traveling or from back-and-forth trips from home to office.
  • Connect devices quickly and easily
    The ports on this hub are upright, which makes it perfect for IT professionals or anyone who needs to plug and unplug their USB devices regularly. You have lots of room to grip the connectors, without the worry of oversized plugs taking up too much space and reducing the number of available ports. With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or simply avoid the hassle of swapping connected devices on your port-limited laptop. The hub makes your USB ports more accessible and can easily extend the range of your devices by acting as a mid-point repeater.
  • Use with high-performance and older devices
    The ST7300U3M supports the latest USB 3.0 products including UASP-enabled; storage devices. With data transfer speeds of up to 5 Gb per second using SuperSpeed USB 3.0 technology, this high-performance hub is the perfect accessory for your desktop, laptop, MacBook, or UltraBook. You can also use the hub with older peripherals and computers, with support for USB 2.0 and 1.x devices and no additional drivers or software required for installation.
StarTech.com 7 Port USB 3.0 Hub (5 Gbps) - Metal Enclosure - Desktop or Wall Mountable - Rugged & industrial Powered USB Expander and Splitter Hub (ST7300U3M) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Metal housing
USB 1.1, USB 2.0, USB 3.0
AC 120/230 V
4.4 cm x 11 cm x 2.4 cm
134 g
P/N: BNDTBUSB3142, MST30C2DPPD, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB3LA
Hub - 7 ports
Enclosure Type
Desktop, wall-mountable
Subtype
USB
Ports
Metal housing
1 x ASMedia ASM1074
7 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
36 Watt
Rubber feet, mounting brackets
1 x SuperSpeed USB cable
FCC, RoHS
4.4 cm
11 cm
2.4 cm
134 g
5 °C
35 °C
20 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
P/N: BNDTBUSB3142, MST30C2DPPD, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
