StarTech.com 7 Port PCI USB Card Adapter
Quicklinx: 6LD1WS00 Mfr#: PCIUSB7
Type: USB adapter
Compatibility: PC
Interface: PCI
Hurry, only 2 left in stock!
£16.51 ex VAT
£19.81 inc VAT
Add 7 USB 2.0 ports to your PC through a PCI slot. This PCI USB card adds seven USB 2.0 ports (1 internal USB A female, 2 internal USB motherboard header, and 4 external USB A female) to your PCI-capable PC.
The PCI USB 2.0 card is a versatile solution that lets you add USB 2.0 connections without having to upgrade the system motherboard.
An all-in-one solution, the PCI USB card supports USB 2.0 device connections for full data transfer speeds of up to 480Mbps, and is backward compatible with USB 1.1 devices (max. transfer rate 12Mbps), allowing you to connect any USB device to the computer without having to worry about compatibility issues.
The adapter card is designed and constructed to provide long-lasting USB capability.
StarTech.com 7 Port PCI USB Card Adapter - PCI to USB 2.0 Controller Adapter Card - Full Profile Expansion Card (PCIUSB7) - USB adapter - PCI - 7 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 2.2
Bus Voltage
Universal (3.3 V & 5.0 V)
12.2 cm x 2 cm x 12 cm
71 g
Ports Qty
7 ports
USB, USB 2.0
Data Transfer Rate
480 Mbps
USB 1.1, USB 2.0
Linux, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista
1-year warranty
USB adapter - 7 ports
Plug-in card
PCI
PCI 2.2
Bus Voltage
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
USB 1.1, USB 2.0
4 x USB 2.0 - 4 pin USB Type A (external) , 1 x USB 2.0 - 4 pin USB Type A (internal) , 2 x USB 2.0 (internal)
Compatible Slots
1 x PCI
WHQL, FCC, RoHS
12.2 cm
2 cm
12 cm
71 g
Limited warranty - 1 year
6LD1 StarTech.com 7 Port PCI USB Card Adapter In Stock £16.51
6LD1 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.76
6LD1 StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £53.18
Type: USB adapter
Compatibility: PC
Interface: PCI
