StarTech.com 7 Port Industrial USB 3.0 Hub
Quicklinx: B7JHWS00 Mfr#: ST7300USBME
Type: USB Hub
Ports: 7
25 in stock
£86.29 ex VAT
£103.54 inc VAT
Add seven USB 3.0 ports with this DIN rail or surface-mountable metal hub. Engineered to meet the challenges of tough industrial environments, this USB 3.0 hub lets you expand your connectivity options by adding seven external USB 3.0 ports to your computer.
Now you can increase your everyday productivity by gaining powerful and convenient access to your external hard drives, printers, mobile devices and other peripherals.
Designed for performance and durability, the industrial-grade hub features a rugged, metal housing. Its wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. Plus, it supports an extended operating temperature range (0°C to 70°C), helping to ensure reliable performance even in the most demanding factory and industrial environments.
The rugged hub also offers ESD protection to each USB port, which can help safeguard your investments by preventing damage to your connected devices.
This wall-mountable USB 3.0 hub can be securely mounted to surfaces, under desks, and in other high traffic areas where there is a concern that USB connections may become unplugged. Plus, it also includes optional DIN rail mounts for use with equipment rack installations.
Compliant with SuperSpeed USB 3.0, this industrial hub supports 5Gbps bandwidth. It's also backward compatible with USB 2.0 and 1.x specifications, simultaneously supporting older USB peripherals or legacy systems that lack USB 3.0 capabilities.
StarTech.com 7-Port Industrial Grade USB 3.0 Hub with ESD & 350W Surge Protection - Rack mountable metal USB port expander splitter hub (ST7300USBME) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Surge protection, rugged, 15KV ESD Protector, metal housing
USB 1.1, USB 2.0, USB 3.0
DC 7 - 48 V
5.5 cm x 12.2 cm x 4.3 cm
650 g
P/N: ITB20D3250, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 7 ports
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
USB
Ports
1 x Genesys Logic GL3520
Status Indicators
7 x USB 3.0 Type A , 1 x USB 3.0 Type B
DC 7 - 48 V
1 x SuperSpeed USB cable
FCC, RoHS
5.5 cm
12.2 cm
4.3 cm
650 g
70 °C
5 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
B7JH StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.21
B7JH StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.79
B7JH StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £74.07
B7JH StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.95
B7JH StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £72.27
B7JH StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £21.47
B7JH StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £38.18
B7JH StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £48.04
B7JH StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £86.29
B7JH StarTech.com 7 Port PCIe USB 3.0 Card In Stock £48.82
B7JH StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.36
Type: USB Hub
Ports: 7
Price Range Ex VAT: 50 - 100
