StarTech.com Industrial USB 3.0 Hub
Quicklinx: HDFVWS00 Mfr#: 5G16AINDS-USB-A-HUB
Type: USB Hub
Interface: USB 3.2
Speed: 5Gbps
Ports: 16
Form Factor: External
10 In Stock
£290.59 ex VAT
£348.70 inc VAT
The 16-port industrial USB 3.0 hub with 5 Gbps of shared bandwidth provides fast and efficient transfer speeds, making it an ideal solution for data-intensive applications. The hub features a 2-port host switch, enabling users to switch between two host devices, streamlining device management. The hub also includes ESD protection to safeguard against static electricity. Additionally, the hub supports USB BC 1.2, enabling fast charging of battery-powered USB devices. The combined features of this USB hub ensure stable and reliable functionality for use in IT and industrial applications.
  • Engineered for use in industrial environments
    This USB hub is built to withstand harsh industrial environments. It features a rugged steel housing that provides protection against physical hazards such as drops and impacts. It is equipped with Level-4 ESD protection, with 15 kV air and 8 kV contact discharge ratings, to safeguard against damage caused by static electricity. These features make the USB hub an excellent choice for use in factories, production lines, and other industrial settings.
  • Connect and charge USB devices
    This USB hub features two 12-24 V DC power options. Power can be inputted using the 2-wire terminal block connector or the barrel connector. Both options enable support for USB Battery Charging Specification 1.2 (BC 1.2) with 120 W shared across all ports. Ports are grouped in 8 pairs and each pair supports max 3.0 A/15 W combined (1.5 A/7.5 W per port), or max 2.0 A/10 W per port when only one of both ports is used.
  • Dual-host switch
    The USB hub can connect to two separate desktop or laptop computers, and features a dual-host switch that enables easy toggling between them. The dual-host switch provides a convenient solution for applications requiring two host devices.
StarTech.com 16-Port Industrial USB 3.0 Hub 5Gbps, Metal, DIN/Surface/Rack Mountable, ESD Protection, Terminal Block Power, up to 120W Shared USB Charging, Dual-Host Hub/Switch (5G16AINDS-USB-A-HUB) - hub - industrial - 16 ports - rack-mountable
Hub - 16 ports
Enclosure Type
Rack-mountable 1U
Subtype
USB
Ports
16 x USB 3.2 Gen 1
Performance
Data transfer rate: 5 Gbps
Screw lock, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), switch button, fast charging support
USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
28 cm x 13 cm x 4.3 cm
1.1 kg
Hub - 16 ports
Enclosure Type
Desktop, rack-mountable, DIN rail mountable 1U
Subtype
USB
Ports
16 x USB 3.2 Gen 1
Performance
1 x Genesys Logic GL3523
Status Indicators
Power, host
16 x USB 3.2 Gen 1 Type A , 2 x USB 3.2 Gen 1 Type B host , 1 x 2 pin terminal block
Mounting screws, 2 rack mount brackets, terminal block connector, 2 DIN-rail mounting brackets
1 x USB-A to USB-B cable - 3 m
MTBF
122,383.8 hours
WEEE
28 cm
13 cm
4.3 cm
1.1 kg
Shipping Weight
1.8 kg
Limited warranty - 2 years , Technical support - assistance - lifetime
60 °C
5 - 95% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
75 °C
HDFV StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
HDFV StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
Type: USB Hub
Interface: USB 3.2
Speed: 5Gbps
Ports: 16
