Add seven USB 3.0 ports with this DIN rail or surface-mountable metal hub. Engineered to meet the challenges of tough industrial environments, this USB 3.0 hub lets you expand your connectivity options by adding seven external USB 3.0 ports to your computer.
Now you can increase your everyday productivity by gaining powerful and convenient access to your external hard drives, printers, mobile devices and other peripherals.
Designed for performance and durability, the industrial-grade hub features a rugged, metal housing. Its wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. Plus, it supports an extended operating temperature range (0°C to 70°C), helping to ensure reliable performance even in the most demanding factory and industrial environments.
The rugged hub also offers ESD protection to each USB port, which can help safeguard your investments by preventing damage to your connected devices.
This wall-mountable USB 3.0 hub can be securely mounted to surfaces, under desks, and in other high traffic areas where there is a concern that USB connections may become unplugged. Plus, it also includes optional DIN rail mounts for use with equipment rack installations.
Compliant with SuperSpeed USB 3.0, this industrial hub supports 5Gbps bandwidth. It's also backward compatible with USB 2.0 and 1.x specifications, simultaneously supporting older USB peripherals or legacy systems that lack USB 3.0 capabilities.
- StarTech.com 7 Port Industrial USB 3.0 Hub - ESD Protection - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x SuperSpeed USB 3.0
- Surge protection, rugged, 15KV ESD Protector, metal housing
- USB 1.1, USB 2.0, USB 3.0
- Power
- DC 7 - 48 V
- 5.5 cm x 12.2 cm x 4.3 cm
- 650 g
- Black
- 2-year warranty
- Designed For
- P/N: ITB20D3250, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Hub - 7 ports
- Enclosure Type
- DIN rail mountable, wall-mountable
- Subtype
- USB
- Ports
- Processor
- 1 x Genesys Logic GL3520
- Status Indicators
- Power
- 7 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Voltage Required
- DC 7 - 48 V
- Black
- Cables Included
- 1 x SuperSpeed USB cable
- FCC, RoHS
- 5.5 cm
- 12.2 cm
- 4.3 cm
- 650 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £89.50 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £25.26 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £81.66 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power | In Stock | £20.24 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £55.80 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £64.12 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £104.26 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £58.61 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £27.93 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £42.96 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £121.41 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £132.68 |
