StarTech.com 7 Port Industrial USB 3.0 Hub
Quicklinx: B7JHWS00 Mfr#: ST7300USBME
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 7
Form Factor: External
45 In Stock
£111.14 ex VAT
£133.36 inc VAT
Add seven USB 3.0 ports with this DIN rail or surface-mountable metal hub. Engineered to meet the challenges of tough industrial environments, this USB 3.0 hub lets you expand your connectivity options by adding seven external USB 3.0 ports to your computer.
Now you can increase your everyday productivity by gaining powerful and convenient access to your external hard drives, printers, mobile devices and other peripherals.
Designed for performance and durability, the industrial-grade hub features a rugged, metal housing. Its wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. Plus, it supports an extended operating temperature range (0°C to 70°C), helping to ensure reliable performance even in the most demanding factory and industrial environments.
The rugged hub also offers ESD protection to each USB port, which can help safeguard your investments by preventing damage to your connected devices.
This wall-mountable USB 3.0 hub can be securely mounted to surfaces, under desks, and in other high traffic areas where there is a concern that USB connections may become unplugged. Plus, it also includes optional DIN rail mounts for use with equipment rack installations.
Compliant with SuperSpeed USB 3.0, this industrial hub supports 5Gbps bandwidth. It's also backward compatible with USB 2.0 and 1.x specifications, simultaneously supporting older USB peripherals or legacy systems that lack USB 3.0 capabilities.
  • Secure Connectivity
    Equipped with seven SuperSpeed USB 3.0 ports, this hub allows simultaneous connection of multiple devices, enhancing productivity and ease of access.
  • Robust Design
    The metal housing adds to the durability of the hub, making it suitable for use in tough industrial environments.
  • Safety Features
    Incorporating 15 kV ESD protection and 350 W surge protection, this hub safeguards connected devices from power surges and electrostatic discharge.
  • Flexible Installation
    This hub can be easily mounted on a DIN rail or wall, providing various installation options to fit different spaces.
  • Wide Operational Range
    With an operating temperature range of 0°C to 70°C and a humidity range of 5% to 95%, this hub is designed to function effectively in diverse environmental conditions.
StarTech.com 7-Port USB 3.0 Hub - Metal Industrial USB-A Hub with ESD Protection & 350W Surge Protection - Din Rail, Wall or Desk Mountable - TAA Compliant USB Expander Hub (ST7300USBME) - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Surge protection, rugged, 15KV ESD Protector, metal housing
USB 1.1, USB 2.0, USB 3.0
DC 7 - 48 V
5.5 cm x 12.2 cm x 4.3 cm
650 g
P/N: ITB20D3250, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 7 ports
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
USB
Ports
1 x Genesys Logic GL3520
Status Indicators
7 x USB 3.0 Type A , 1 x USB 3.0 Type B
DC 7 - 48 V
1 x SuperSpeed USB cable
FCC, RoHS
5.5 cm
12.2 cm
4.3 cm
650 g
70 °C
5 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
B7JH StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
B7JH StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.85
B7JH StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £82.82
B7JH StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £19.93
B7JH StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.34
B7JH StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £63.50
B7JH StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.14
B7JH StarTech.com 7 Port PCIe USB 3.0 Card In Stock £58.33
B7JH StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £131.31
B7JH StarTech.com 4-Port Industrial USB 2.0 Hub In Stock £146.36
B7JH StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £40.79
B7JH StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £115.92
B7JH StarTech.com 4 Port USB C Hub 10Gbps In Stock £120.71
B7JH StarTech.com Industrial USB 2.0 Hub In Stock £115.92
B7JH StarTech.com Industrial USB 3.0 Hub In Stock £306.30
B7JH StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
Type: USB Hub
Speed: 5Gbps
Ports: 7
