StarTech.com 7.5 m CAT6a Cable - Grey- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5MWS00 Mfr#: 6ASPAT750CMGR
Length: 7.5m
Colour: Grey
£14.07 ex VAT
£16.88 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks. Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
The shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • Reliable performance
    This patch cable is equipped with RFI/EMI shielding, allowing for consistent data transmission while minimizing interference from external factors.
  • Durable construction
    The molded and snagless design ensures that connectors remain intact and free from damage during setup and use, enhancing longevity.
  • High speed capability
    With a tested frequency of up to 500 MHz, this cable is capable of handling high-speed data transmission, making it suitable for various network applications.
  • Robust material
    The PVC jacket provides protection against wear and tear, ensuring the cable can endure various environmental conditions without compromising performance.
  • Standard compliance
    This Ethernet cable meets RoHS and ANSI/TIA-568-C.2 standards, assuring users of adherence to recognized safety and quality benchmarks.
StarTech.com 7.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT750CMGR) - patch cable - 7.5 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
7.5 m
290 g
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 7.5m
Colour: Grey
