The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks. Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
The shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
High-performance shielding
This cable features aluminum-polyester foil shielding to effectively reduce RFI and EMI interference, ensuring a clear signal for faster data transmission. -
Robust construction
Made with a sturdy PVC jacket, this cable is designed to withstand everyday wear and tear, providing a reliable solution for any networking setup. -
Efficient design
The molded and snagless design of the connectors allows for smooth plug-in and removal, preventing damage during connections and disconnections.
 - StarTech.com 7.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT750CMBL) - patch cable - 7.5 m - blue
 - Patch cable - CAT 6a
- Technology
 - Shielded twisted pair (STP)
- Shielding Material
 - Aluminium-polyester foil
- Wires per Cable
 - 8 wires
 - Molded, snagless, RFI/EMI shielding
- Length
 - 7.5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Blue
 - Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 26
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Length
 - 7.5 m
 - 290 g
 - Blue
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
