StarTech.com 7.5 m CAT6a Cable - Blue- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5KWS00 Mfr#: 6ASPAT750CMBL
Length: 7.5m
Colour: Blue
£14.07 ex VAT
£16.88 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks. Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
The shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • High-performance shielding
    This cable features aluminum-polyester foil shielding to effectively reduce RFI and EMI interference, ensuring a clear signal for faster data transmission.
  • Robust construction
    Made with a sturdy PVC jacket, this cable is designed to withstand everyday wear and tear, providing a reliable solution for any networking setup.
  • Efficient design
    The molded and snagless design of the connectors allows for smooth plug-in and removal, preventing damage during connections and disconnections.
StarTech.com 7.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT750CMBL) - patch cable - 7.5 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
7.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
7.5 m
290 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 7.5m
Colour: Blue
