7.5 m CAT6 Patch Cable , Snagless , 100% Copper Wire Purple ETL Verified. This CAT6 cable meets all Category 6 cable specifications, to deliver a reliable Gigabit network connection.
Protect Your Equipment
This CAT6 patch cable is built using 100% copper wire and are tested to comply with ANSI/TIA 568 C.2 Category 6 requirements. We don't use copper-clad aluminum (CCA) wire, which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
High-Quality Construction
The CAT6 cable is manufactured using high-quality copper conductors and carefully constructed and tested to keep Near-End Crosstalk (NEXT) well within acceptable limits. The patch cable is constructed with 24 AWG copper wire, to ensure peak performance for demanding Ethernet applications such as Power-over-Ethernet and 4K or 1080p video streaming.
Easily Install Your Network Cables
For trouble-free cable runs, this durable cable feature snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6 Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
N6PATC750CMPL is backed by a StarTech.com lifetime warranty for guaranteed reliability.
100% copper for outstanding value
Get high value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors. -
24-gauge wire for high-performance network connections
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet, using cables that include 24 AWG copper. -
50-micron gold connectors provide peak conductivity
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 7.5m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Purple, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC750CMPL) - patch cable - 7.5 m - purple
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 7.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Purple
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7.5 m
- 1.16 cm
- 0.82 cm
- 320 g
- Purple
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, REACH, ANSI/TIA-568-C.2, CMG, TIA/EIA-568-B.1-2001 - up to 650 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 330 g
