StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel
Quicklinx: 7B8BWS00 Mfr#: WALLMOUNT6
Product Type: Cabinet
Hurry, only 3 left in stock!
£49.48 ex VAT
£59.37 inc VAT
This 6U (12in) high steel mounting bracket delivers a sturdy and dependable equipment storage option, allowing you to wallmount equipment for a more efficient and accessible operating environment. The mounting bracket features an all-steel design.
  • Durable construction
    Made from high-quality steel, this bracket ensures long-lasting durability and strength to support network equipment.
  • Space-saving design
    Designed to be wall-mounted, it maximizes floor space and provides a tidy installation for easy access to cables and equipment.
  • Standard rack compatibility
    The 19-inch rack size is compliant with standards, allowing for a wide range of compatible equipment to be mounted.
StarTech.com Wall Mount Patch Panel Bracket - 6U - 14in Deep (WALLMOUNT6) - cabinet - 6U
Cabinet
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
6U
Product Material
Steel
Cabinet
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
6U
7B8B StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.68
7B8B StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
7B8B StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7B8B StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.62
7B8B StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
7B8B StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
7B8B StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7B8B StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7B8B StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
7B8B StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
7B8B StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.59
7B8B StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7B8B StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7B8B StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
7B8B StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7B8B StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
7B8B StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7B8B StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7B8B StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7B8B StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7B8B StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7B8B StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.86
7B8B StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7B8B StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7B8B StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
7B8B StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7B8B StarTech.com 12U WM Bracket for 12 INCH Equipment In Stock £122.14
7B8B StarTech.com 8U WM Bracket for 12in Equipment In Stock £103.61
7B8B StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
7B8B StarTech.com 18U Server Rack Enclosure In Stock £379.01
7B8B StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
7B8B StarTech.com 26U Server Rack Enclosure In Stock £475.05
7B8B StarTech.com 9U Wall-Mount Rack Cabinet In Stock £183.55
7B8B StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
7B8B StarTech.com 12U Server Rack Enclosure In Stock £338.60
7B8B StarTech.com 12U Server Rack Enclosure In Stock £283.26
7B8B StarTech.com 15U Server Rack Enclosure In Stock £327.54
7B8B StarTech.com 12U Server Rack Enclosure In Stock £385.18
7B8B StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
7B8B StarTech.com 4U Wall Mount Rack, 13.78in Deep, 19 inch Wall Mount Network In Stock £46.00
7B8B StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
