Extend the reach of your USB 3.0 port by 6 inches. The USB3EXT6INBK USB 3.0 extension cable extends the reach of a USB 3.0 port on your laptop or desktop computer by 6 inches and gives you more room for connecting multiple devices.
The cable can also help to prevent damage to the USB 3.0 port on your computer in testing environments or other situations where the port is accessed repeatedly.
The extension allows you to connect multiple devices at once, such as flash drives, and gives you open access to ports, even when they are located closely together.
The cable can also be used as a port saver in busy environments where cables are unplugged and re-inserted frequently.
Connect multiple USB devices
The extension allows you to connect multiple devices at once, such as flash drives, and gives you open access to ports, even when they are located closely together. -
Eliminate damage to your USB 3.2 Gen 1 port
The cable can also be used as a port saver in busy environments where cables are unplugged and re-inserted frequently. Designed and constructed for maximum durability, this high quality cable is backed by StarTech.com's Lifetime Warranty.
- StarTech.com 6in Short USB 3.0 Extension Adapter Cable (USB-A Male to USB-A Female) - USB 3.1 Gen 1 (5Gbps) Port Saver Cable - Black (USB3EXT6INBK) - USB extension cable - USB Type A to USB Type A - 15.2 cm
- Molded
- Length
- 15.2 cm
- Connector
- 9 pin USB Type A - female
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: 35FCREADBU3, HB30A4AIB, HB30C4AIB, HB31C4AB, SU2DUPERA11, USB3SAA3MBK
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Molded
- Length
- 15.2 cm
- Black
- Connector
- USB 3.0, RoHS
- Designed For
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.71 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.71 |
StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F | In Stock | £11.99 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.99 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.41 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.29 |
