The USB3AAEXT10M, 10-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 10-meters (32.8-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
The USB3AAEXT10M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
Reliable signal regeneration
The active cable technology allows for signal regeneration, ensuring high-quality data transfer over distances up to 32.8 feet without signal degradation. -
High-speed data transfer
This extension cable supports USB 3.1 Gen 1 with speeds up to 5 Gbps, making it suitable for transferring large files quickly and efficiently. -
Durable construction
Featuring nickel-plated connectors, this cable is built to withstand wear while maintaining reliable connections for all your devices. -
Safety compliant
The cable adheres to FCC and RoHS standards, ensuring that it is safe for use and environmentally friendly. -
Versatile connectivity
Designed with a male to female configuration, this USB extension cable can be used with a wide range of USB devices, providing flexibility in device placement.
- StarTech.com 32.8 ft Active USB 3.0 Extension Cable with AC Power Adapter - Shielded - Male to Female USB USB 3.1 Gen 1 Type A (5Gbps) Extender (USB3AAEXT10M) - USB extension cable - USB Type A to USB Type A - 10 m
- Active cable (signal regeneration)
- Length
- 10 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB / USB 2.0 / USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: PEXUSB3S42V, PEXUSB3S44V, S352BU33HR, SVA5H2NEUA, USB3SAA3MBK
- Plated Connector
- Nickel
- Length
- 10 m
- Black
- Connector
- USB / USB 2.0 / USB 3.0, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £72.26 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £84.93 |
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £115.60 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.41 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.29 |
