StarTech.com 6in SATA Serial ATA Cable
Quicklinx: 76PTWS00 Mfr#: SATA6
Length: 15cm
More than 50 in stock
£3.08 ex VAT
£3.69 inc VAT
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA6 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 6in SATA Serial ATA Cable - SATA cable - Serial ATA 150/300 - SATA (F) to SATA (F) - 5.9 in - red - SATA6 - SATA cable - 15 cm
SATA cable
Interface Speed
Serial ATA 150/300
Length
15 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: 25SATSAS35, 25SATSAS35HD, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Shielding Material
PVC
American Wire Gauge (AWG)
26
Length
15 cm
Red
Connector
RoHS
Length: 15cm
Stock Status: In stock
