StarTech.com 18" Serial ATA Cable w/R Angle
Quicklinx: 3ZLJWS00 Mfr#: SATA18RA1
Length: 45.7cm
Type: ATA
More than 50 In Stock
£5.00 ex VAT
£6.00 inc VAT
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA18RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 18-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 18in Left Angle SATA cable (SATA18LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
  • Flexible design
    The right-angle connector allows for greater flexibility and ease of connection in tight spaces, helping to maintain a clean and organized setup.
  • High-speed performance
    With support for Serial ATA interface speeds of 150, 300, and 600, this cable provides fast data transfer essential for efficient storage solutions.
  • Secure connectivity
    Utilizing two 7 pin receptacle connectors, this cable ensures a reliable and stable connection, reducing the risk of data loss during transmission.
  • Environmentally friendly
    Designed to comply with RoHS standards, this cable reflects a commitment to environmental responsibility while providing high-performance connectivity.
StarTech.com 18in SATA to Right Angle SATA Serial ATA Cable - 18in SATA Cable - 18 SATA Cable - 18in angled SATA Cable - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
45.7 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, 35S24M2NGFF, CFAST2SAT25, MSAT2SAT3, PATA2SATA3, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT34RH, S251BU31REM, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX, SATABAY5BK, ST521PMINT
Storage Cable Type
SATA cable
Interface Speed
Length
45.7 cm
Red
Connector
RoHS
3ZLJ StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
3ZLJ StarTech.com 6in SATA Serial ATA Cable In Stock £3.55
3ZLJ StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable In Stock £3.85
3ZLJ StarTech.com 0.3m SATA Extension Cable In Stock £7.42
Length: 45.7cm
Type: ATA
