StarTech.com 6in Latching Round SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 9M71WS00 Mfr#: LSATARND6R1
Make a right-angled connection to your SATA drive, for installation in tight spaces. The LSATARND6R1 6-inch Round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure cooling for improved system performance.
The cable features one straight latching SATA connector, as well as a right-angled latching SATA connector that makes it easier to connect your SATA drive even if space near the drive is limited. The latching connectors also ensure secure connections to SATA hard drives and motherboards that support this feature.
StarTech.com 6in Latching Round SATA to Right Angle SATA Serial ATA Cable - 6" Round Latching Right Angle SATA Cable - Improved Air Flow (LSATARND6R1) - SATA cable - 15.24 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched, round, right-angled connector
Length
15.24 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
P/N: 35S24M2NGFF, CFAST2SAT25, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
30
Length
15.24 cm
Connector
RoHS
9M71 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
