Connect latching SATA drives while helping to ensure optimal airflow throughout a desktop or server case. The LSATARND6 6-inch latching round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure optimal cooling for optimized system performance. This durable cable also features latching connectors, which lock when connected to a supporting (latchable) SATA port to, ensuring a snug, secured data connection every time to prevent accidental disconnects.
- StarTech.com 6in Latching Round SATA Cable - 6 SATA Cable - 6 round SATA Cable - 6 latching SATA Cable (LSATARND6) - SATA cable - 15.2 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Latched, round
- Length
- 15.2 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXESAT322I, S251BU31REM, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Interface Speed
- American Wire Gauge (AWG)
- 30
- Latched, round
- Length
- 15.2 cm
- Black
- Connector
- RoHS
- Designed For
