This 6in 4 Pin (LP4) Molex to SATA power adapter cable features one 4 Pin Molex (LP4) male connector and one female SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
- StarTech.com 6in 4 Pin LP4 to SATA Power Cable Adapter - LP4 to SATA - 6in LP4 to SATA Cable - 4 pin to SATA power - power cable - SATA power to 4 PIN internal power - 0.2 m
- Power cable
- Length
- 0.2 m
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 4 PIN internal power - male
- Limited lifetime warranty
- Designed For
- P/N: BNDTBUSB3142, BRACKET125PT, BRACKET125PTP, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB43SATSASB, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, SATBP125VP
- Power cable
- Length
- 0.2 m
- Connector
- Designed For
- P/N: 25SAT35HDD, 35BAYUSB3S4, ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, BNDTBUSB3142, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25SAT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PATA2SATA3, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, RMC2300, S32M2NGFFPEX, SAT2MSAT25, SAT32MSATPEX, SATBP125VP
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.20 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.40 |
StarTech.com 8in 15 pin SATA Power Extension Cable | In Stock | £6.18 |
StarTech.com 12in 15 pin SATA Power Extension Cable | In Stock | £8.16 |
StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable Adapter | In Stock | £3.97 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.48 |
StarTech.com 12in Molex LP4 Power Extension Cable – M/F | In Stock | £4.34 |
