Power a SATA hard drive from a conventional LP4 power supply connection. The SATAPOWADPL Molex to 90-degree SATA power adapter features one 4-Pin Molex (LP4) male connector and a left angle, 90-degree SATA power connector (female), which enables you to power a Serial ATA hard drive from a conventional LP4 connection and eliminates the need to upgrade the computer power supply for compatibility with the SATA hard drive.
The 90-degree (left angle) SATA power connector makes it easier to connect a SATA drive that's installed in hard to reach areas or tight spaces, avoiding the strain on both the connector and cable.
- StarTech.com 6in 4 Pin LP4 to Left Angle SATA Power Cable Adapter - LP4 to SATA Power Adapter (SATAPOWADPL) - power adapter - SATA power to 4 PIN internal power - 15 cm
- Power adapter
- Left-angled connector
- Length
- 15 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 4 PIN internal power - male
- Limited lifetime warranty
- Power adapter
- Length
- 15 cm
- Connector
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.48 |
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter | In Stock | £4.16 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.38 |
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter | In Stock | £5.01 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.38 |
