This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 6 ft. away.
The adapter works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 6 ft. (1.8 m) in length, this adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, StarTech.com also offers a 6 ft. (1m) USB-C to DP cable (CDP2DPMM1MB), enabling you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your desktop, laptop or tablet. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're trying to dock your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
Astonishing Picture Quality
The?USB C to DisplayPort adapter cable?lets you harness the video capabilities that are built into?your USB-C connection, to deliver the astonishing quality of Ultra HD to your 4K display and supporting resolutions up to 3840 x 2160. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments. -
Clutter-Free Installation
At 6 ft. (1.8 m) in length, this?monitor cable eliminates the need for excess adapters and cabling,?ensuring?a tidy, professional installation. For installations requiring shorter or longer connections we also offer a 9.8 ft. (3 m) (CDP2DPMM3MB, CDP2DPMM3MW) and a 3.3 ft. (1 m) (CDP2DPMM1MB, CDP2DPMM1MW)?USB-C?to DP?cable, enabling you to choose the right cable length for your custom installation needs. -
Hassle-Free Setup
To ensure easy operation and installation, this?USB C to DisplayPort cable?works with?both?Windows and Mac?computers?and?allows for?plug-and-play installation, removing the need for any additional software or drivers. CDP2DPMM6B?is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note:?Your USB-C port must support DisplayPort over USB-C (DP Alt mode) in order to work with this adapter.
- StarTech.com 6ft/1.8m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Works with Thunderbolt 3, Black - USB-C Male to DP Male - DisplayPort cable - 24 pin USB-C to DisplayPort - 1.8 m
- DisplayPort cable
- 4K60Hz (3840 x 2160) support, HBR2 support, DisplayPort Alternate Mode support, 21.6 Gbps data rate, 5.1 audio channel support
- Length
- 1.8 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 20 pin DisplayPort - male (output)
- Displayport 1.2/Thunderbolt 3
- Black
- 3-year warranty
- Designed For
- P/N: TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- DisplayPort cable
- Length
- 1.8 m
- Black
- 49 g
- Connector
- Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.9 cm
- Shipping Weight
- 58 g
- 3-year warranty
- Designed For
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.24 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £26.57 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £15.74 |
StarTech.com USB-C to HDMI Adapter | In Stock | £22.55 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £31.86 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £28.93 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £55.32 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £24.05 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £30.91 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £17.15 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £23.78 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £24.35 |
StarTech.com 1m USB C to DP Cable - White | In Stock | £25.76 |
StarTech.com 6 ft USB C to DP Cable - White | In Stock | £28.51 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £31.45 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £31.92 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £27.46 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £34.17 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.38 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £26.61 |
StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter | In Stock | £13.97 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £33.46 |
