USB Type-C Adapter Cable 8K 30Hz Thunderbolt 3 HBR3. This USB-C to DisplayPort 1.4 cable lets you connect your USB Type-C (or Thunderbolt 3 ) device to a DisplayPort display, or a DP device to a USB-C display with just one cable.
Unparalleled Performance with Support for 8K 30Hz
Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
Easy & Clutter-Free Installation
At 3.3 ft. (1 m) in length, this bi-directional adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, we also offer a 6.6 ft. (2 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 8K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. For added convenience, the cable supports both Mac & Windows operating systems.
CDP2DP141MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB-C device must support DP Alt Mode to work with this cable.
Unparalleled Performance with Support for 8K 60Hz
Supporting four times the resolution of 4K, this 8K DP 1.4 adapter cable delivers the stunning quality of UHD at resolutions up to 7680×4320; and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps. The video cable is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation. -
IT Pro Performance
This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands. -
At 3.3 ft. (1 m) in length, this?bi-directional adapter cable delivers a compact?connection that eliminates excess adapters and cabling,?ensuring?a tidy, professional installation. For longer installations, we also offer a 6.6 ft. (2 m) USB-C?to DP?cable, enabling you to choose the right cable length for your custom installation needs. -
Use this USB-C to DisplayPort adapter cable to output 8K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input. For added convenience, the cable supports both Mac & Windows operating systems. CDP2DP141MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: • Your USB-C device must support DP Alt Mode to work with this cable. • To achieve 8K resolutions, your source and your destination must support DisplayPort 1.4. • This cable is not compatible with the Surface Dock 2
- StarTech.com 3ft/1m USB C to DisplayPort 1.4 Cable 8K 60Hz/4K, Bidirectional DP to USB-C or USB-C to DP Reversible Video Adapter Cable, HBR3/HDR/DSC, USB Type C/Thunderbolt 3 Monitor Cable - 8K USB-C to DP Cable (CDP2DP141MBD) - DisplayPort cable - 24 pin USB-C to DisplayPort - 1 m
- DisplayPort cable
- Active cable, 8K UHD (7680 x 4320) support, DisplayPort Alternate Mode support, bidirectional, High Bit Rate 3 (HBR3)
- Length
- 1 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- USB 3.1 / Thunderbolt 3 / DisplayPort 1.4
- Black
- 3-year warranty
- DisplayPort cable
- Length
- 1 m
- Black
- Connector
- USB 3.1 / Thunderbolt 3 / DisplayPort 1.4, cUL, FCC, RoHS, WEEE, REACH
- 3-year warranty
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.44 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.89 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.97 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £32.74 |
