StarTech.com 6ft USB-C to DisplayPort Cable
Quicklinx: C53CWS00 Mfr#: CDP2DPMM6B
Length: 1.8m
Select:
More than 50 In Stock
£28.80 ex VAT
£34.56 inc VAT
This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 6 ft. away.
The adapter works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 6 ft. (1.8 m) in length, this adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, StarTech.com also offers a 6 ft. (1m) USB-C to DP cable (CDP2DPMM1MB), enabling you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your desktop, laptop or tablet. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're trying to dock your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Astonishing Picture Quality
    The?USB C to DisplayPort adapter cable?lets you harness the video capabilities that are built into?your USB-C connection, to deliver the astonishing quality of Ultra HD to your 4K display and supporting resolutions up to 3840 x 2160. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
  • Clutter-Free Installation
    At 6 ft. (1.8 m) in length, this?monitor cable eliminates the need for excess adapters and cabling,?ensuring?a tidy, professional installation. For installations requiring shorter or longer connections we also offer a 9.8 ft. (3 m) (CDP2DPMM3MB, CDP2DPMM3MW) and a 3.3 ft. (1 m) (CDP2DPMM1MB, CDP2DPMM1MW)?USB-C?to DP?cable, enabling you to choose the right cable length for your custom installation needs.
  • Hassle-Free Setup
    To ensure easy operation and installation, this?USB C to DisplayPort cable?works with?both?Windows and Mac?computers?and?allows for?plug-and-play installation, removing the need for any additional software or drivers. CDP2DPMM6B?is backed by a 3-year StarTech.com warranty and free lifetime technical support. Note:?Your USB-C port must support DisplayPort over USB-C (DP Alt mode) in order to work with this adapter.
StarTech.com 6ft/1.8m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Works with Thunderbolt 3, Black - USB-C Male to DP Male - DisplayPort cable - 24 pin USB-C to DisplayPort - 1.8 m
DisplayPort cable
4K60Hz (3840 x 2160) support, HBR2 support, DisplayPort Alternate Mode support, 21.6 Gbps data rate, 5.1 audio channel support
Length
1.8 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - male (output)
Displayport 1.2/Thunderbolt 3
3-year warranty
P/N: TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort cable
Length
1.8 m
49 g
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.9 cm
Shipping Weight
58 g
3-year warranty
C53C StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £13.51
C53C StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £15.57
C53C StarTech.com USB-C to VGA Adapter - White In Stock £21.61
C53C StarTech.com USB-C to HDMI Adapter In Stock £22.69
C53C StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
C53C StarTech.com 6ft USB-C to DisplayPort Cable In Stock £28.80
C53C StarTech.com 2m USB-C to DVI Cable In Stock £24.14
C53C StarTech.com 2m USB-C to HDMI Cable In Stock £30.76
C53C StarTech.com USB-C to VGA - Power Delivery In Stock £23.19
C53C StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.82
C53C StarTech.com USB-C to HDMI - Power Delivery In Stock £25.73
C53C StarTech.com USB-C to DisplayPort Adapter In Stock £23.87
C53C StarTech.com USB-C to DisplayPort Adapter In Stock £23.09
C53C StarTech.com USB-C to DP MST Hub - 3-Port In Stock £53.09
C53C StarTech.com 1m USB C to DP Cable - White In Stock £24.72
C53C StarTech.com 6 ft USB C to DP Cable - White In Stock £28.24
C53C StarTech.com 3m USB C to DisplayPort Cable - White In Stock £30.46
C53C StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £32.46
C53C StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £26.59
C53C StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £32.54
C53C StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.36
C53C StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £25.52
C53C StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £14.02
C53C StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £23.00
C53C StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £24.71
C53C StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £27.49
C53C StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £29.45
C53C StarTech.com Portable USB C to HDMI Adapter with Keychain In Stock £18.81
C53C StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £32.41
Length: 1.8m
