StarTech.com 6ft USB-C to A Cable - USB 2.0
Quicklinx: CJS9WS00 Mfr#: USB2AC2M
Length: 2m
More than 50 In Stock
£11.87 ex VAT
£14.24 inc VAT
Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using the USB-A port on your computer. You can also use the cable to charge your USB-C mobile devices from a standard USB-A wall or car charger.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
  • Charge and sync your mobile devices over longer distances
  • Provide superior connections with USB-IF-certified cables
    The cable has undergone rigorous compliance testing and is certified by USB-IF to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
StarTech USB C to USB Cable - 6 ft / 2m - USB A to C - USB 2.0 Cable - USB Adapter Cable - USB Type C - USB-C Cable (USB2AC2M) - USB-C cable - USB-C to USB - 2 m
USB-C cable
Double shielded
Cable Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, ST4200MINIC
USB-C cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Cable Length
2 m
44 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
CJS9 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
CJS9 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
CJS9 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
CJS9 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
CJS9 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
CJS9 StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
CJS9 StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
CJS9 StarTech.com USB-C to Micro-USB Adapter M/F In Stock £4.59
CJS9 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
CJS9 StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £7.94
Length: 2m
