Eliminate adapters, by connecting your HDMI source directly to a VGA monitor/projector using this 6ft adapter cable. The HD2VGAMM6 6ft HDMI to VGA converter cable lets you connect your HDMI equipped Chromebook, laptop or desktop to a VGA monitor or projector, with no additional adapters or cables required.
The converter cable saves you the hassle of combining an HDMI to VGA adapter with a bulky VGA cable by providing an end-to-end solution for connecting your digital HDMI computer to your VGA monitor or projector.
Unlike most HDMI to VGA adapters which require a power outlet to convert the video signal, the HD2VGAMM6 doesn't need external power in most installations. To work with Mac computers where extra power is needed, the HD2VGAMM6 features an optional integrated USB power source (USB cable not included), which makes connecting a display to your desktop or workstation that much easier, if additional power is required.
In the past, converting digital HDMI to analog VGA was a difficult and expensive task. Now, you can avoid upgrade costs by connecting your HDMI video source to your existing VGA monitor or projector using the HD2VGAMM6. Plus, because the adapter cable supports video resolutions up to 1920x1200 or 1080p, you can rest assured you can use your existing VGA display while maintaining high-definition video quality.
The HD2VGAMM6 converter cable delivers a precise 6ft connection that eliminates the clutter of excess cable length and ensures a tidy, professional installation. For longer shorter installations, StarTech.com offers a 3 ft HDMI to VGA cable (HD2VGAMM3), and longer installations StarTech.com offers a 10 ft HDMI to VGA cable (HD2VGAMM10), enabling you to choose the right cable length for your installation needs.
Digitally encrypted content from the HDMI video source will not be displayed.
High-resolution support
The maximum output resolution of 1920 x 1200 ensures that visuals are clear and detailed, accommodating various display resolutions for different applications. -
Active cable functionality
The active design of the cable allows it to convert digital HDMI signals to analog VGA, ensuring compatibility with a wide range of monitors and displays. -
USB-powered convenience
This cable features USB-powered functionality, providing consistent power to the conversion chip for optimal performance, especially beneficial for older VGA displays.
- StarTech.com HDMI to VGA Cable - 6ft 2m - 1080p - Active Conversion - HDMI to VGA Adapter Cable for Your VGA Monitor / Display (HD2VGAMM6) - adapter cable - HDMI / VGA - 2 m
- Cable
- Adapter cable - HDMI / VGA
- Max Output Resolution
- 1920 x 1200
- Length
- 2 m
- Black
- Connectors
- HDMI - male , Micro-USB Type B (power only) - female
- Connectors (Second End)
- HD-15 (VGA) - male
- Active cable, 1920 x 1200 (WUXGA) support
- 3-year warranty
- Designed For
- P/N: MST30C2DPPD
- Cable Type
- Adapter cable active, 1920 x 1200 (WUXGA) support
- Interface Supported
- HDMI / VGA
- Length
- 2 m
- USB powered
- Black
Adapters & Converters
- 1920 x 1200
- Connectors
- 19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
- 15 pin HD D-Sub (HD-15) - male
- FCC, RoHS
- 112.8 g
- Shipping Width
- 19.8 cm
- Shipping Depth
- 22.3 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 130 g
- Limited warranty - 3 years
- Designed For
- P/N: MST30C2DPPD
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.10 |
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £13.35 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p | In Stock | £13.96 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.81 |
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 | In Stock | £22.95 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.15 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £14.78 |
StarTech.com 10ft HDMI to VGA adapter cable | In Stock | £34.95 |
StarTech.com 3ft HDMI to VGA adapter cable | In Stock | £17.68 |
StarTech.com 6ft HDMI to VGA adapter cable | In Stock | £20.08 |
StarTech.com HDMI to VGA Adapter w/ Audio | In Stock | £12.56 |
