StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops
Quicklinx: 93JPWS00 Mfr#: HD2VGAMICRO
12 In Stock
£14.78 ex VAT
£17.73 inc VAT
Connect an HDMI device/computer to a VGA monitor or projector, with this slim adapter ideal for laptops/Ultrabooks. The HD2VGAMICRO HDMI to VGA converter lets you connect an HDMI output from your Ultrabook, Chromebook or laptop computer to a VGA monitor or projector.
With no external power adapter required, and a small form factor design, this portable HDMI to VGA adapter is a great accessory to have on-hand in your laptop carrying case. Plus, this easy-to-use converter supports plug-and-play installation, which speeds up installation time eliminates hassle.
The converter delivers maximum video quality, with support for resolutions up to 1920x1200/1080p - a convenient solution for boosting productivity by extending your computer's desktop onto to a secondary monitor.
  • Versatile compatibility
    This adapter converts HDMI signals to VGA, allowing users to connect modern devices to older VGA displays, making it suitable for different environments.
  • High output resolution
    With support for resolutions up to 1920 x 1200, this adapter delivers a clear and detailed image, enhancing visual experiences for presentations and media.
  • Active adapter design
    The active adapter design ensures reliable signal conversion, reducing issues with compatibility while maintaining quality performance.
  • Efficient refresh rate
    The 60 Hz refresh rate provides smooth video output, making it ideal for both still images and dynamic content.
  • Compliance assured
    Compliant with several standards such as FCC and RoHS, this adapter ensures adherence to safety and environmental regulations.
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops - 1920x1200/1080p - adapter - HDMI / VGA - 4.5 cm
Cable
Adapter - HDMI / VGA
Max Output Resolution
1920 x 1200 - 60 Hz
Length
4.5 cm
Connector
HDMI - male (input)
Connector (Second End)
HD-15 (VGA) - female
Active adapter
3-year warranty
P/N: DKT30CSDHPD3, SV211HDUC, SV221HUC4K
Cable Type
Adapter active
Interface Supported
HDMI / VGA
Length
4.5 cm
Slim
Adapters & Converters
1920 x 1200
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male (input)
15 pin HD D-Sub (HD-15) - female
FCC, RoHS, WEEE, REACH, RCM
2.1 cm
1.4 cm
Shipping Width
17.5 cm
Shipping Depth
14 cm
Shipping Height
3 cm
Shipping Weight
11 g
Limited warranty - 3 years
93JP StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £13.96
93JP StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.81
93JP StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £22.95
93JP StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.15
93JP StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.78
93JP StarTech.com 10ft HDMI to VGA adapter cable In Stock £34.95
93JP StarTech.com 3ft HDMI to VGA adapter cable In Stock £17.68
93JP StarTech.com 6ft HDMI to VGA adapter cable In Stock £20.08
93JP StarTech.com HDMI to VGA Adapter w/ Audio In Stock £12.56
