High performance connectivity
This DisplayPort cable is compliant with DisplayPort 1.4 standards, ensuring quality transmission for both video and audio. With its HBR3 support, users benefit from enhanced bandwidth for demanding applications. -
Reliable high-definition output
Allows for striking visual quality with support for 8K resolution at 60Hz and 4K at 120Hz. This makes it suitable for high-resolution displays and advanced gaming setups. -
Durable construction
Features a thermoplastic elastomer jacket and aluminum mylar foil shielding for long-lasting durability and protection against interference, ensuring stable performance during use. -
Enhanced audio capabilities
Supports up to 32 audio channels and provides options for both 5.1 and 7.1 audio channel transmissions, delivering a rich acoustic experience for varied audio needs. -
Versatile compatibility
This cable is designed for maximum compatibility with various devices, thanks to its VESA certification and compliance with industry standards like HDCP 2.2.
- StarTech.com 6ft (2m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM2M) - DisplayPort cable - DisplayPort to DisplayPort - 2 m
- DisplayPort cable
- Technology
- Shielded
- Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
- Length
- 2 m
- Connector
- 20 pin DisplayPort - male
- Connector (Second End)
- DisplayPort 1.4
- Grey, black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 34
- Plated Connector
- Gold
- Length
- 2 m
- Outside Diameter
- 4.5 mm
- Grey, black
- Connector
- DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 88 g
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £13.89 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £12.18 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £19.69 |
