StarTech.com 4-Port Dual-Monitor KVM Switch
Quicklinx: HKKXWS00 Mfr#: P4DD46A2-KVM-SWITCH
Type: KVM / audio switch
Ports: 4
Connectivity: KVM
£643.27 ex VAT
£771.92 inc VAT
  • Robust construction
    The KVM switch is built with a durable steel housing that ensures long-lasting performance and protection from physical damage.
  • High-performance video support
    With support for a maximum resolution of 3684 x 2160 at 60 Hz, this switch delivers stunning visuals for an enhanced viewing experience.
  • User-friendly operation
    Hotkey and push-button functionalities streamline switching between systems, making it quick and efficient for daily use.
  • Advanced connectivity options
    Featuring multiple ports including USB 5Gbps and 2.0 HID ports, the switch easily connects various peripherals for increased productivity.
  • Environmental compliance
    The switch is compliant with FCC, RoHS, and WEEE standards, ensuring safe use and minimal environmental impact.
StarTech.com 4-Port Dual-Monitor DisplayPort KVM Switch, 4K 60Hz, 2x USB 5Gbps Hub Ports, 2x USB 2.0 HID Ports, Hotkey and Push-Button Switching, TAA Compliant - 3.5mm Audio, HDCP (P4DD46A2-KVM-SWITCH) - KVM / audio switch - 4 ports - TAA Compliant
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
4K resolution support, Auto Scan Mode, 8KV ESD Protector (air-gap discharge), 6KV ESD Protector (contact discharge), steel housing, built-in buzzer, push button, EMI/RFI protection, hotkeys
AC 100-240 V 1 A
10 cm x 25.3 cm x 6.6 cm
1.2 kg
Japan, New Zealand, North America, United Kingdom, Europe
TAA Compliant
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3684 x 2160 @ 60 Hz
Status Indicators
Port status
2 x DisplayPort input , 2 x USB 3.0 input 9 pin USB header female , 2 x USB 2.0 input Type A female , 2 x audio input mini-jack female , 8 x DisplayPort output , 4 x USB 3.2 Gen 1 output Type B , 8 x audio output mini-jack
External power adapter
Power Provided
3 A
AC 100-240 V
Electric Current Required
1 A
0.1 Watt
MTBF
103,062 hours
FCC, RoHS, WEEE
TAA Compliant
10 cm
25.3 cm
6.6 cm
1.2 kg
Shipping Width
16.2 cm
Shipping Depth
33.2 cm
Shipping Height
12.9 cm
Shipping Weight
1.4 kg
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
HKKX StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
HKKX StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.40
HKKX StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
HKKX StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £21.09
HKKX StarTech.com 16ft DisplayPort 1.4 8K 60Hz In Stock £35.91
HKKX StarTech.com 2-Port Dual-Monitor KVM Switch In Stock £306.00
HKKX StarTech.com 4-Port DisplayPort KVM Switch In Stock £360.65
HKKX StarTech.com Dual-Monitor DP 1.4 KVM Switch In Stock £407.28
HKKX StarTech.com 2-Port DisplayPort KVM Switch In Stock £300.12
HKKX StarTech.com 2-Port DisplayPort + HDMI KVM In Stock £295.89
Ports: 4
Connectivity: KVM
Price Range Ex VAT: £500 - £750
