High-resolution support
Experience stunning visual clarity with 4K 60Hz resolution support, making it ideal for graphic design, high-definition gaming, and video editing. -
Efficient connectivity
Features multiple USB 3.2 Gen 1 and USB 2.0 ports along with DisplayPort and audio connections, providing a seamless interface for all your peripherals. -
Enhanced durability
Built with a rugged metal housing and equipped with 6 kV and 8 kV ESD protectors, this KVM switch is designed to withstand the rigors of daily use. -
Easy control
Switch between devices effortlessly with the push of a button or hotkey commands, enhancing productivity and user experience. -
Reliable performance
With a data transfer rate of 5 Gbps and support for HDR10 and deep color, enjoy reliable performance and vibrant image quality.
- StarTech.com 4-Port DisplayPort KVM Switch, 4K 60Hz, TAA Compliant - KVM / audio / USB switch - 4 ports - TAA Compliant
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Performance
- Data transfer rate: 5 Gbps
- Rugged, metal housing, Pushbutton/Hotkey switching, 8KV ESD Protector (air-gap discharge), HDR support, 10-bit Deep Colour support, 6KV ESD Protector (contact discharge), HDR10 support, 2 channel analogue audio, EMI protection, BIOS/UEFI control
- USB 3.2 Gen 1
- Power
- AC 100-240 V
- 22 cm x 13 cm x 4.4 cm
- 1 kg
- Black
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- TAA Compliant
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Performance
- Max Resolution
- 4096 x 2160 @ 60 Hz
- Rugged, metal housing, Pushbutton/Hotkey switching, 8KV ESD Protector (air-gap discharge), HDR support, 10-bit Deep Colour support, 6KV ESD Protector (contact discharge), HDR10 support, 2 channel analogue audio, EMI protection, BIOS/UEFI control, Auto Scan mode
- USB 3.2 Gen 1
- Processor
- 1 x Genesys Logic GL3523
- Status Indicators
- Port status
- 1 x DisplayPort output console , 2 x USB 3.2 Gen 1 Type A console , 4 x USB 2.0 Type A console , 1 x audio mini-jack console , 4 x DisplayPort host , 4 x USB 3.2 Gen 1 Type B host , 4 x audio mini-jack host
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 100-240 V
- 36 Watt
- Black
- Included Accessories
- Rubber feet set
- MTBF
- 130,000 hours
- RoHS, WEEE, DisplayPort 1.2, HDCP 1.4
- TAA Compliant
- Localisation
- 22 cm
- 13 cm
- 4.4 cm
- 1 kg
- Shipping Width
- 41 cm
- Shipping Depth
- 21.2 cm
- Shipping Height
- 8.7 cm
- Shipping Weight
- 1.2 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80% RH
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 3ft DisplayPort 1.4 8K 60Hz | In Stock | £14.26 |
StarTech.com 6ft DisplayPort 1.4 8K 60Hz | In Stock | £14.98 |
StarTech.com 10ft DisplayPort 1.4 8K 60Hz | In Stock | £20.57 |
StarTech.com 2-Port DisplayPort KVM Switch | In Stock | £292.80 |
StarTech.com 2-Port DisplayPort + HDMI KVM | In Stock | £288.68 |
