StarTech is a high technology company that designs, manufactures and distributes a complete line of computer cables, parts, peripheral sharing and networking products, and productivity enhancing accessories.
With StarTech.com's new Replacement Ball Bearing Fan, you can avoid overheating problems caused by fan failure.
 - StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X2TX3) - system fan kit
- Product Type
 - System fan kit
- Fan Diameter
 - 60 mm
- Fan Height
 - 20 mm
- Rotation Speed
 - 4500 rpm
- Air Flow
 - 22.1 cfm
- Noise Level
 - 28 dB
- Power Connector
 - 3-pin plug
 - Dual ball bearing
 - 6 cm x 6 cm x 2 cm
 - 38 g
 - 2-year warranty
- Designed For
 - P/N: RMC4450
- Product Type
 - System fan kit
 - 6 cm
 - 6 cm
 - 2 cm
 - 38 g
Heatsink & Fan
- Fan Diameter
 - 60 mm
- Fan Height
 - 20 mm
- Rotation Speed
 - 4500 rpm
- Air Flow
 - 22.1 cfm
- Noise Level
 - 28 dB
- Power Connector
 - 3-pin plug
 - Dual ball bearing
 - Limited warranty: - 2 years
 - -10 °C
 - 80 °C
- Designed For
 - StarTech.com 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply
