StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
Quicklinx: 4040WS00 Mfr#: FAN6X25TX3H
Type: Case Fan
£6.65 ex VAT
£7.98 inc VAT
This 6cm x 2.5cm (5000 RPM) Computer Case Fan helps prevent computer systems from overheating, thereby increasing efficiency and stability.
The fan features a TX3 connection and a built-in tachometer that sends RPM signals to your motherboard - a high-performance solution that can help avoid overheating and system failure.
  • Efficient cooling system
    The 60 mm diameter maximizes airflow while maintaining a compact size, allowing for efficient cooling in various setups.
  • Durability through design
    The dual ball bearing construction promotes longevity and stability, ensuring reliable operation over time.
  • Real-time performance tracking
    Fan speed monitoring allows users to track the performance of the fan, helping to ensure the system remains cool and efficient.
StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X25TX3H) - system fan kit
System fan kit
Fan Diameter
60 mm
6 cm x 6 cm x 2.5 cm
25 g
1-year warranty
System fan kit
6 cm
6 cm
2.5 cm
25 g
Heatsink & Fan
Fan Diameter
60 mm
Limited warranty: replacement - 1 year , Parts and labour
4040 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.81
Type: Case Fan
