StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
Quicklinx: 403ZWS00 Mfr#: FAN6X2TX3
Type: Case Fan
£8.74 ex VAT
£10.48 inc VAT
StarTech is a high technology company that designs, manufactures and distributes a complete line of computer cables, parts, peripheral sharing and networking products, and productivity enhancing accessories.
With StarTech.com's new Replacement Ball Bearing Fan, you can avoid overheating problems caused by fan failure.
StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X2TX3) - system fan kit
System fan kit
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4500 rpm
Air Flow
22.1 cfm
Noise Level
28 dB
Power Connector
3-pin plug
Dual ball bearing
6 cm x 6 cm x 2 cm
38 g
P/N: RMC4450
System fan kit
6 cm
6 cm
2 cm
38 g
Heatsink & Fan
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4500 rpm
Air Flow
22.1 cfm
Noise Level
28 dB
Power Connector
3-pin plug
Dual ball bearing
Limited warranty: - 2 years
-10 °C
80 °C
StarTech.com 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply
403Z StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3 In Stock £6.65
403Z StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.81
403Z StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan In Stock £5.50
Type: Case Fan
