StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0
Quicklinx: 87PQWS00 Mfr#: ST7320USBC
Ports: 6
Hurry, only 1 left in stock!
£31.04 ex VAT
£37.24 inc VAT
Add 2x USB 3.0 and 4x USB 2.0 ports to a computer, externally through a single USB 3.0 connection. The ST7320USBC 6-Port USB 3.0/2.0 Combo Hub features a special high-output dedicated charging port which enables you to charge USB devices by providing up to 2A of power, or it can add 2x USB 3.0 and 4x USB 2.0 ports to a computer through a single USB 3.0 host connection.
The hub includes an external power adapter, which when connected enables charging some portable electronic devices (e.g. an iPhone or other Smartphone), even without a USB connection to a host computer.
Offering a unique design that features USB ports along 3 sides of the hub, as well as a combination of USB 2.0 and 3.0 ports, this versatile and flexible USB hub is ideal for both laptop and desktop computers.
StarTech.com 7 Port USB Hub - 2 x USB 3A, 4 x USB 2A, 1 x Dedicated Charging Port - Multi Port Powered USB Hub with 20W Power Adapter (ST7320USBC) - hub - 6 ports
Hub - 6 ports
Subtype
USB
Ports
2 x SuperSpeed USB 3.0 + 4 x USB 2.0
AC 120/230 V
6 cm x 9.9 cm x 2 cm
75.4 g
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.2 - 10.6
P/N: FCREADMICRO3, MSDREADU2OTG, MSDREADU3CA, SDMSDRWU3AC, USB221SS, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Hub - 6 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Status Indicators
4 x USB 2.0 Type A , 2 x USB 3.0 Type A , 1 x USB 3.0 Type B
External power adapter
AC 120/230 V
1 x SuperSpeed USB cable
FCC, RoHS
6 cm
9.9 cm
2 cm
75.4 g
85 °C
5 - 90%
Min Storage Temperature
-10 °C
Max Storage Temperature
95 °C
Ports: 6
Price Range Ex VAT: 0 - 50
