Add 2x USB 3.0 and 4x USB 2.0 ports to a computer, externally through a single USB 3.0 connection. The ST7320USBC 6-Port USB 3.0/2.0 Combo Hub features a special high-output dedicated charging port which enables you to charge USB devices by providing up to 2A of power, or it can add 2x USB 3.0 and 4x USB 2.0 ports to a computer through a single USB 3.0 host connection.
The hub includes an external power adapter, which when connected enables charging some portable electronic devices (e.g. an iPhone or other Smartphone), even without a USB connection to a host computer.
Offering a unique design that features USB ports along 3 sides of the hub, as well as a combination of USB 2.0 and 3.0 ports, this versatile and flexible USB hub is ideal for both laptop and desktop computers.
Versatile connectivity options
This hub includes both two SuperSpeed USB 3.0 ports and four USB 2.0 ports, allowing for efficient connection of multiple devices simultaneously. -
Reliable power management
Equipped with an external power adapter, this USB hub ensures stable and consistent power supply to all connected devices. -
Eco-friendly compliance
The product meets FCC and RoHS standards, highlighting its commitment to environmental safety and user well-being. -
Sleek desktop form factor
The compact and stylish design fits seamlessly into any workspace, making it a convenient choice for home and office use. -
Operational efficiency
Designed to function in a wide temperature range of 0°C to 85°C, this hub is reliable across various environments and usage scenarios.
- StarTech.com 7 Port USB Hub - 2 x USB 3A, 4 x USB 2A, 1 x Dedicated Charging Port - Multi Port Powered USB Hub with 20W Power Adapter (ST7320USBC) - hub - 6 ports
- Hub - 6 ports
- Subtype
- USB
- Ports
- 2 x SuperSpeed USB 3.0 + 4 x USB 2.0
- Power
- AC 120/230 V
- 6 cm x 9.9 cm x 2 cm
- 75.4 g
- Black
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.2 - 10.6
- 2-year warranty
- Designed For
- P/N: FCREADMICRO3, MSDREADU2OTG, MSDREADU3CA, SDMSDRWU3AC, USB221SS, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Hub - 6 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Power
- 4 x USB 2.0 Type A , 2 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 1 x SuperSpeed USB cable
- FCC, RoHS
- OS Required
- 6 cm
- 9.9 cm
- 2 cm
- 75.4 g
- Limited warranty - 2 years
- 0 °C
- 85 °C
- 5 - 90%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 95 °C
- Designed For
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £38.00 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £19.33 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £19.33 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.43 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £24.95 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £47.70 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £62.29 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.74 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £63.21 |
StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £44.32 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £56.18 |
StarTech.com USB to Ethernet Adapter - 1Gb | In Stock | £20.50 |
