Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 6ft black cable. The MDP2VGAMM6B 6ft active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped device (Desktop PC, Mac, Laptop, Ultrabook, etc.) directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your Mini DisplayPort computer to work with a VGA monitor or projector.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 6ft Mini DisplayPort to VGA Cable - Active - 1920x1200 - mDP to VGA Adapter Cable for Your Computer Monitor (MDP2VGAMM6B) - video adapter cable - Mini DisplayPort to HD-15 (VGA) - 1.8 m
- Video adapter cable
- Active cable, 1920 x 1200 (WUXGA) support
- Length
- 1.8 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - male
- Displayport 1.2/Thunderbolt
- Black
- 3-year warranty
- Length
- 1.8 m
- Black
- 101.3 g
- Connector
- Displayport 1.2/Thunderbolt, FCC, RoHS
- Shipping Width
- 19.7 cm
- Shipping Depth
- 22.2 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 123 g
- 3-year warranty
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £6.04 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £17.69 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £16.89 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.01 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £7.03 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £14.18 |
