Connect a VGA display to a Mini-DisplayPort -equipped PC or Mac computer. The MDP2VGAW Mini-DisplayPort to VGA Adapter (White) offers an easy-to-use VGA/Mini-DisplayPort link that enables you to connect a VGA computer monitor to a device with a Mini-DisplayPort output (such as a laptop video out port) or video card.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a Mini DisplayPort video source to a VGA monitor without sacrificing video quality.
Easily connect your Mini DisplayPort computer to a VGA display
The mDP to VGA adapter lets you connect your Mini DisplayPort laptop, desktop or tablet to a VGA display. The adapter is compatible with mDP ports as well as Thunderbolt 1 and Thunderbolt 2 I/O ports, and supports plug-and-play connectivity ensuring a hassle-free setup. -
Works with legacy VGA monitors
The Mini DisplayPort adapter makes your mDP computer fully compatible with existing VGA monitors or projectors in your home or around your office. The VGA connector features nuts that mate with the screws on standard VGA cables, to ensure your video cable won't get disconnected. -
The perfect travel companion for your MacBook with Mini DisplayPort
With its all-white design, this Mini DisplayPort video adapter is the perfect travel accessory for your MacBook with mDP. The adapter is compact and lightweight so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office. While the adapter looks great next your Mac it also works with any Mini DisplayPort computer, such as your Windows laptop. -
Crystal-clear picture quality
With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your mDP connection to deliver every detail in stunning high-definition. The MDP2VGAW is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com Mini DisplayPort to VGA Adapter - White - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA Converter (MDP2VGAW) - video converter - white
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
- 4.5 cm x 18 cm x 1.5 cm
- Enclosure Colour
- White
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female
- Active cable (signal regeneration)
- Cables Included
- - 12 cm
- FCC, RoHS, WEEE, DisplayPort 1.1a
- 4.5 cm
- 18 cm
- 1.5 cm
- 31 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com Mini DisplayPort to VGA Video Adapter Converter | In Stock | £16.84 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £5.38 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £20.53 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £16.14 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £7.69 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI | In Stock | £23.82 |
