Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
High compatibility
This 6 ft HDMI to DVI cable offers a practical solution for connecting HDMI-capable devices to DVI-D equipment, enabling users to enjoy a reliable connection between their computer and a DVI monitor or projector. -
Reliable quality
Crafted with high-quality materials, this video adapter cable ensures optimal performance. The durable design ensures a secure connection and prolonged lifespan, making it a wise investment for digital monitor setups. -
Effortless installation
Featuring a Plug-and-Play design, this cable simplifies the setup process, eliminating the need for complicated installation or additional software. Users can easily connect their devices and enjoy high-resolution video in minutes.
- StarTech.com 6ft (1.8m) HDMI to DVI Cable, DVI-D to HDMI Display Cable (1920x1200p), Black, 19 Pin HDMI Male to DVI-D Male Cable Adapter, Digital Monitor Cable, M/M, Single Link - DVI to HDMI Cord (HDMIDVIMM6) - adapter cable - 1.83 m
- Cable
- Adapter cable
- Length
- 1.83 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Designed For
- P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, MDP2HDEC, MSTCDP122HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS424HD4K60
- Cable Type
- Adapter cable
- Length
- 1.83 m
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- Limited warranty - lifetime
- Designed For
- P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDEC, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTCDP122HD, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USB3SMDOCKHV, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.55 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.35 |
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £64.55 |
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £42.49 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.05 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.71 |
StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £63.44 |
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 | In Stock | £22.78 |
StarTech.com HDMI Coupler / Gender Changer - F/F | In Stock | £8.37 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £22.93 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £47.72 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £35.15 |
