StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip
Quicklinx: FBZDWS00 Mfr#: HD2MF6INL
Length: 15.2cm
18 In Stock
£10.94 ex VAT
£13.12 inc VAT
This High Speed HDMI port saver cable prevents wear and tear on the HDMI port on your monitor or other devices, by extending it away from the device for a more flexible connection. The port extender cable supports all HDMI 2.0 specifications, including resolutions up to 4K (60Hz), and bandwidth up to 18Gbps.
To prevent accidental disconnections and signal loss, the extender features a high-retention HDMI male connector. The connector automatically latches to the inside of the port, creating contact pressure that prevents it from loosening over time due to movement or vibrations.
This short male-to-female extension cable supports all HDMI 2.0 specifications: Resolutions up to 4K 60Hz; High speeds with a bandwidth of up to 18Gbps; High Dynamic Range for higher contrast ratio and vivid colors; Crystal-clear sound with up to 32 uncompressed digital audio channels; Supports 21:9 cinema aspect ratio and 3D video; Backward compatible with earlier versions of HDMI; Supports Consumer Electronics Control (CEC) functions.
Fully compatible with your HDMI 2.0 equipment, this port saver cable supports resolutions up to 4K 60Hz and bandwidths up to 18Gbps. It's also backward compatible with earlier versions of HDMI and will work with all of your existing HDMI devices.
  • Secure Port Connection
  • Full HDMI Capability
    This short male-to-female extension cable supports all HDMI 2.0 specifications: • Resolutions up to 4K 60Hz • High speeds with a bandwidth of up to 18Gbps • High Dynamic Range for higher contrast ratio and vivid colors • Crystal-clear sound with up to 32 uncompressed digital audio channels • Supports 21:9 cinema aspect ratio and 3D video • Backward compatible with earlier versions of HDMI • Supports Consumer Electronics Control (CEC) functions
  • Enjoy Astonishing Picture Quality
    Fully compatible with your HDMI 2.0 equipment, this port saver cable supports resolutions up to 4K 60Hz and bandwidths up to 18Gbps. It's also backward compatible with earlier versions of HDMI and will work with all of your existing HDMI devices. HD2MF6INL?is backed by a StarTech.com lifetime warranty and free lifetime technical support
StarTech.com 6in High Speed HDMI Port Saver Cable with 4K 60Hz - Short HDMI 2.0 Male to Female Adapter Cable - Port Extender (HD2MF6INL) - HDMI extension cable - 15.2 cm
Cable
Double shielded
American Wire Gauge (AWG)
30
Max Output Resolution
3840 x 2160 - 60 Hz
Length
15.2 cm
Connector
HDMI - male - straight
Connector (Second End)
HDMI - female - straight
4K support
Cable Type
HDMI extension cable 4K support
Double shielded
30
Jacket Material
PVC
Shielding Material
Length
15.2 cm
Plated Connector
Gold
3D over HDMI, HDR support, gripping connectors
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male - straight
19 pin HDMI Type A - female - straight
CEC
2.22 cm
0.4 cm
25 g
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Weight
30 g
Limited warranty - lifetime
FBZD StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
FBZD StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.20
FBZD StarTech.com HDMI Port Saver Cable 18inch In Stock £7.60
FBZD StarTech.com HDMI Port Saver Cable 3ft In Stock £8.80
FBZD StarTech.com HDMI Port Saver Cable 6ft In Stock £10.97
Length: 15.2cm
