StarTech.com 6 ft HDMI to DVI-D Cable - M/M
Quicklinx: 4JDRWS00 Mfr#: HDMIDVIMM6
Type: HDMI
Length: 1.83m
Select:
  • 2m
30 In Stock
£7.92 ex VAT
£9.50 inc VAT
Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
  • High compatibility
    This 6 ft HDMI to DVI cable offers a practical solution for connecting HDMI-capable devices to DVI-D equipment, enabling users to enjoy a reliable connection between their computer and a DVI monitor or projector.
  • Reliable quality
    Crafted with high-quality materials, this video adapter cable ensures optimal performance. The durable design ensures a secure connection and prolonged lifespan, making it a wise investment for digital monitor setups.
  • Effortless installation
    Featuring a Plug-and-Play design, this cable simplifies the setup process, eliminating the need for complicated installation or additional software. Users can easily connect their devices and enjoy high-resolution video in minutes.
StarTech.com 6ft (1.8m) HDMI to DVI Cable, DVI-D to HDMI Display Cable (1920x1200p), Black, 19 Pin HDMI Male to DVI-D Male Cable Adapter, Digital Monitor Cable, M/M, Single Link - DVI to HDMI Cord (HDMIDVIMM6) - adapter cable - 1.83 m
Cable
Adapter cable
Length
1.83 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, MDP2HDEC, MSTCDP122HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS424HD4K60
Cable Type
Adapter cable
Length
1.83 m
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
Limited warranty - lifetime
P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDEC, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTCDP122HD, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USB3SMDOCKHV, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
4JDR StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
4JDR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £10.12
4JDR StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £69.22
4JDR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male In Stock £10.40
4JDR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
4JDR StarTech.com USB 3 to HDMI w/ USB Hub In Stock £62.29
4JDR StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200 In Stock £24.04
4JDR StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.59
4JDR StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £23.14
4JDR StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £51.16
4JDR StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £36.04
4JDR StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £12.94
Type: HDMI
Length: 1.83m
