Connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDMIDVIMM6 6-foot HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
- StarTech.com CAT5e Cable - 10 ft Gray Ethernet Cord - Molded - CAT5e Patch Cord - CAT5e UTP Cable - RJ45 Network Cable - adapter cable - 1.83 m
- Cable
- Adapter cable
- Length
- 1.83 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- Designed For
- P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, MDP2HDEC, MSTCDP122HD, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, USB32HD2, USBC2DVCAPRO, UVCHDCAP, VID2HDCON2, VS424HD4K60
- Cable Type
- Adapter cable
- Length
- 1.83 m
- Black
- Connector
- 19 pin HDMI Type A - male
- 18+1 pin digital DVI (Single-Link) - male
- Limited warranty - lifetime
- Designed For
- P/N: BNDDKT30CAHV, BOX4CABLE, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CDVPD, DKWG30DPHPD, DKWG30DPHPDU, DP2DVI, DP2DVI2, DP2DVIS, DP2HD4KS, DP2HDMI, DP2HDMI2, DP2HDMIADAP, DVI92030202L, DVISPL1DD, HDBOOST, HDMI2HDMI, HDMI2VGA, HDMIPNLFM3, HDVGADP2HD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, MDP2HD4KS, MDP2HDEC, MDP2HDMI, MDP2HDW, MHD2HDF11, MSTCDP122HD, MSTDP123HD, MSTMDP123HD, MSTP3MDPUGBK, MSTS3MDPUGBK, RKCOND17HD, ST121HD20FXA, ST121HDBTSC, ST121HDFXA, ST121HDWP, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTPHD2, ST121WHD2, ST121WHDS, ST122DVIA, ST122HD4K, ST122HD4KU, ST122HDMI2, ST122HDMILE, ST124DVIA, ST124HD4K, ST124HDMI2, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST424HDBT, STDHVHDBT, STHDBTRX, SV831DVIU, TB32HD2, USB2DVIE3, USB2DVIPRO2, USB2HDCAPS, USB32DVCAPRO, USB32DVIEH, USB32DVIPRO, USB32HD2, USB32HD4K, USB32HDDVII, USB32HDEH, USB32HDES, USB32HDPRO, USB3SMDOCKHV, USBC2DVCAPRO, UVCHDCAP, VGA2HD2, VID2HDCON, VID2HDCON2, VS221HD2VGA, VS221HD4K, VS221HD4KA, VS221HDQ, VS221VGA2HD, VS222HD4K, VS222HDQ, VS420RDVIA, VS421HD4K, VS421HD4KA, VS421HDPIP, VS424HD4K60, VS424HDPIP, VS440HDMI, VS721MULTI, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.80 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.28 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £8.98 |
StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F | In Stock | £9.82 |
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £76.61 |
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £88.91 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £8.74 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.40 |
StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £72.78 |
StarTech.com USB 3.0 to DVI External Video Card Multi Monitor Adapter with 1-Port USB Hub 1920x1200 | In Stock | £48.65 |
StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £70.69 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £58.65 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £62.12 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £73.21 |
StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip | In Stock | £12.00 |
