Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6FL 6-foot Flat High Speed HDMI Cable with Ethernet supports Ethernet data interconnectivity with compatible HDMI devices and features a flat-shaft design that makes it suitable for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
Durable design
The PVC jacket and aluminum mylar foil shielding offer resistance against wear while protecting the integrity of the signal, ensuring dependable performance over time. -
Flexible installation
The flat cable design allows for easy routing along walls and corners, making it an ideal choice for both home theaters and professional setups. -
High-speed performance
Designed to support HDMI with Ethernet, this cable delivers fast data transfer rates, providing seamless connectivity for streaming and gaming applications.
 - StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - Flat HDMI Cable (HDMIMM6FL) - HDMI cable with Ethernet - 1.8 m
- Cable
- American Wire Gauge (AWG)
 - 24
- Length
 - 1.8 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - Limited lifetime warranty
- Cable Type
 - 24
- Jacket Material
 - PVC
- Shielding Material
 - Aluminum mylar foil with braid
- Length
 - 1.8 m
- Plated Connector
 - Gold
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - RoHS
 - Limited warranty - lifetime
