StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7NYVWS00 Mfr#: HDMIMM6FL
Length: 1.8m
£8.60 ex VAT
£10.32 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6FL 6-foot Flat High Speed HDMI Cable with Ethernet supports Ethernet data interconnectivity with compatible HDMI devices and features a flat-shaft design that makes it suitable for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
  • Durable design
    The PVC jacket and aluminum mylar foil shielding offer resistance against wear while protecting the integrity of the signal, ensuring dependable performance over time.
  • Flexible installation
    The flat cable design allows for easy routing along walls and corners, making it an ideal choice for both home theaters and professional setups.
  • High-speed performance
    Designed to support HDMI with Ethernet, this cable delivers fast data transfer rates, providing seamless connectivity for streaming and gaming applications.
StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - Flat HDMI Cable (HDMIMM6FL) - HDMI cable with Ethernet - 1.8 m
Cable
American Wire Gauge (AWG)
24
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
24
Jacket Material
PVC
Shielding Material
Length
1.8 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7NYV StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £8.60
Length: 1.8m
